I recently started programming with Arduino and CanBus shield Elecfreaks. Currently I’m making a project ‘new’ cluster into an older vehicle. I want to use CAN bus shield for ARDUINO UNO and my goal is to write a program to convert some input data in hex format into CAN ID and send them on CAN bus CLUSTER.
So, can I use it in inverse application? (to put data on CAN bus) and send it(variable) over CAN bus protocol via cluster (canbus).
Anyone can help my problem?
Question 1) How to make it variable for byte5 & byte6 (speed)
Question 2) It is possible vss square wave (PWM) convert to HEX can id?
If can’t. How to make it variable PWM at byte5 & byte6.
Thanks
paul_reference.ino (3.81 KB)
