I don't know what happened... Arduino ran fine last time I used it. Today I tried opening it and got this message
"Arduino cannot run because it could not create a folder to store your settings."
I have Arduino 022, arduino 1.0 and processing installed in my system.... all three stopped working and give me the same error message.
I checked the preferences.txt file in
C:/users/fxmech/appData/Arduino
reads:
last.sketch5.location=812,40,500,992,819
export.application.fullscreen=false
preproc.imports.list=java.applet.,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.,java.net.,java.text.,java.util.,java.util.zip.,java.util.regex.*
editor.font.macosx=Monaco,plain,10
preproc.web_colors=true
last.sketch2.path=C:\Users\fxmech\Desktop\armtests\DavidSUPER_FINALTx_further2\DavidSUPER_FINALTx_further2_pde\DavidSUPER_FINALTx_further2_pde.pde
export.application.platform=true
update.check=true
update.id=9074203461584183919
editor.indent=true
serial.stopbits=1
serial.databits=8
editor.font=Monospaced,plain,12
editor.window.height.default=600
run.options.memory=false
editor.divider.size=2
editor.caret.blink=true
preproc.color_datatype=true
export.applet.separate_jar_files=false
last.sketch3.path=C:\Users\fxmech\Documents\Documents\Arduino\arduino-1.0\libraries\XBee\examples\Series1_Rx\Series1_Rx.pde
editor.update_extension=true
preproc.output_parse_tree=false
run.window.bgcolor=#F0F0F0
console.lines=4
upload.using=bootloader
console.error.file=stderr.txt
run.options.memory.maximum=256
editor.tabs.expand=true
editor.window.height.min=530
editor.keys.home_and_end_travel_far=false
board=diecimila
console=true
run.present.exclusive.macosx=true
last.sketch4.path=C:\Users\fxmech\Documents\Documents\Arduino\arduino-1.0\libraries\LPD8806\EXAMPLES\locoLED23\locoLED23.ino
serial.parity=N
editor.tabs.size=2
console.length=500
last.sketch0.location=-4,-4,1928,1036,854
serial.port=COM19
last.sketch2.location=285,435,500,600,427
run.options=
console.auto_clear=true
update.last=1336766728444
last.sketch4.location=865,4,585,997,824
editor.window.width.min=400
run.present.exclusive=false
export.application.platform.linux=true
last.sketch6.location=215,222,500,600,427
last.sketch5.path=C:\Users\fxmech\AppData\Local\Temp\untitled2133632202565610254.tmp\sketch_mar15f\sketch_mar15f.ino
editor.keys.home_and_end_travel_far.macosx=true
editor.window.height.min.windows=530
run.present.bgcolor=#666666
export.application.platform.windows=true
target=arduino
run.options.memory.initial=64
editor.keys.alternative_cut_copy_paste=true
editor.window.width.default=500
console.output.file=stdout.txt
preproc.substitute_unicode=true
run.present.stop.color=#cccccc
editor.external=false
last.screen.height=1080
last.sketch6.path=C:\Users\fxmech\AppData\Local\Temp\untitled2133632202565610254.tmp\sketch_mar15g\sketch_mar15g.ino
editor.keys.shift_backspace_is_delete=true
editor.window.height.min.macosx=450
last.sketch.count=0
export.delete_target_folder=true
last.sketch0.path=C:\Users\fxmech\Documents\Arduino\Wild_Thumper_Controller3\Wild_Thumper_Controller3.ino
last.serial.location=887,185,837,637
preproc.substitute_floats=true
editor.keys.alternative_cut_copy_paste.macosx=false
serial.line_ending=1
browser.linux=mozilla
editor.invalid=false
serial.debug_rate=9600
sketchbook.path=C:\Users\fxmech\Documents\Arduino
export.application.stop=true
editor.divider.size.windows=2
last.sketch1.path=C:\Users\fxmech\Desktop\armtests\DavidSUPER_FINALTx_further2\DavidSUPER_FINALTx_further2_pde\DavidSUPER_FINALTx_further2_pde.pde
preproc.enhanced_casting=true
run.display=1
last.sketch1.location=810,340,500,600,427
platform.auto_file_type_associations=false
editor.antialias=false
programmer=arduino:avrispmkii
last.sketch3.location=620,40,1059,817,644
preproc.save_build_files=false
last.screen.width=1920
export.application.platform.macosx=true
I do have a folder called C:/users/fxmech/My Documents/Arduino
and my sketches are in there...
User fxmech is the administrator (and only) user on this windows 7 PC....
Any ideas??? I tried re uploading Arduino 1.0 and installing it in a new folder for that one gave me the same error message....
