I used a premade sketch from a tutorial:
#define trig 3
#define echo 2
int thresholddistance = 30;
long duration;
float forwarddistance;
float distancefront;
float distanceArr[6];
#include <Servo.h>
#define pinServo 4
//----------------------------------------------------- Initialization: Setting up Servo Angles
int servoArray[6] = {0, 25, 50, 110, 145, 180};
Servo myServo;
//----------------------------------------------------- Initialization: Motors
int motor_left[] = {9, 6};
int motor_right[] = {11, 10};
//----------------------------------------------------- Initialization: Setup Module
myServo.attach(pinServo);
//Setup Motors
for (int i = 0; i < 2; i++)
pinMode(motor_left[i], OUTPUT);
pinMode(motor_right[i], OUTPUT);
//Setup Sensor
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
//----------------------------------------------------- Initialization: Motor Module
// Following Module is for the Robot to brake
void brake()
digitalWrite(motor_left[0], LOW);
digitalWrite(motor_left[1], LOW);
digitalWrite(motor_right[0], LOW);
digitalWrite(motor_right[1], LOW);
// Following Module is for the Robot to go forward
void drive_forward()
delayMicroseconds(400);
digitalWrite(motor_left[1], HIGH);
delayMicroseconds(1000 - 400);
digitalWrite(motor_right[1], HIGH);
// Following Module is for the Robot to slightly go towards left
void slight_left()
delay(600);
// Following Module is for the Robot to slightly go towards right
void slight_right()
delay(600);
// Following Module is for the Robot to turn left
void turn_left()
delay(900);
// Following Module is for the Robot to turn right
void turn_right()
delay(900);
// Following Module is to make a uturn if there are obstacles to the right, to the left and in front
void turn_around()
digitalWrite(motor_left[0], HIGH);
digitalWrite(motor_right[0], HIGH);
delay(600);
//----------------------------------------------------- Sight Forward
float distance(int angle) {
myServo.write(angle);
digitalWrite(trig, LOW);
delayMicroseconds(20);
digitalWrite(trig, HIGH);
duration = pulseIn(echo, HIGH);
forwarddistance = duration / 58;
return forwarddistance;
//----------------------------------------------------- Sensor Array Module
void scan_around() {
for (int i = 0; i < 6; i++) {
myServo.write(servoArray[i]);
delay(100);
distanceArr[i] = duration / 58;
Serial.print("distanceArr[");
Serial.print(i);
Serial.print("] = ");
Serial.println(distanceArr[i]);
delay(100);
//----------------------------------------------------- Loop Module
void loop(){
myServo.write(75);
distancefront = distance(75);
Serial.println(distancefront);
// Serial.println(thresholddistance);
if ((distancefront > thresholddistance) && (distancefront < 1000))
drive_forward();
Serial.println("1");
else {
brake();
scan_around();
if ((distanceArr[1] > 1000) && (distanceArr[2] > 1000) && (distanceArr[3] > 1000) && (distanceArr[4] > 1000) && (distanceArr[5] > 1000) && (distanceArr[6] > 1000))
return;
Serial.println("Restarted the Loop");
delay(100);
else if (((distanceArr[1]) > 30.0) && ((distanceArr[2]) > 30.0))
slight_right();
drive_forward();
Serial.println("2");
else if (((distanceArr[0]) > 30.0) && ((distanceArr[1]) > 30.0))
turn_right();
drive_forward();
Serial.println("3");
else if (((distanceArr[3]) > 30.0) && ((distanceArr[4]) > 30.0))
slight_left();
drive_forward();
Serial.println("4");
else if (((distanceArr[4]) > 30.0) && ((distanceArr[5]) > 30.0))
turn_left();
drive_forward();
Serial.println("5");
turn_around();
brake();
slight_left();
drive_forward();
Serial.println("6");
// delay(100);
