Arduino car problem
d
show code (with code tags not a table) where you tried to integrate the buttons and explain how you plan to wire those buttons. (why do you need 2 buttons if you have only 2 modes - one permanent switch would be enough)
#include <NewPing.h>
#include <Servo.h>
#define TRIG_PIN A4
#define ECHO_PIN A5
#define MAX_DISTANCE 200
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
const int motorPin1  = 11;
const int motorPin2  = 10;
//Motor B
const int motorPin3  = 6;
const int motorPin4  = 5;
  myservo.attach(9);
  myservo.write(115);
  delay(2000);
  distance = readPing();
  delay(100);
  delay(100);
  delay(100);
  delay(100);
 int distanceR = 0;
 int distanceL =  0;
 delay(40);
 if(distance<=20)
  moveStop();
  delay(100);
  moveBackward();
  delay(300);
  moveStop();
  delay(200);
  distanceR = lookRight();
  delay(200);
  distanceL = lookLeft();
  delay(200);
  if(distanceR>=distanceL)
    turnRight();
    moveStop();
  }else
    turnLeft();
    moveStop();
 }else
  moveForward();
int lookRight()
    myservo.write(50);
    int distance = readPing();
    delay(100);
    myservo.write(115);
    return distance;
int lookLeft()
    myservo.write(170);
    delay(100);
    myservo.write(115);
    return distance;
    delay(100);
int readPing() {
  delay(70);
  int cm = sonar.ping_cm();
  if(cm==0)
    cm = 250;
  return cm;
void moveStop() {
  analogWrite(motorPin1, 0);
    analogWrite(motorPin2, 0);
    analogWrite(motorPin3, 0);
    analogWrite(motorPin4, 0);
void moveForward() {
    analogWrite(motorPin1, 180);
    analogWrite(motorPin3, 180);
void moveBackward() {
    analogWrite(motorPin2, 180);
    analogWrite(motorPin4, 180);
void turnRight() {
  delay(300);
 moveForward();
void turnLeft() {
  delay(300);
   moveForward();
where are your buttons?
come on.. where is YOUR attempt at integrating codes...
I give up.
