Arduino car
Ok I have this arduino powered autonomes car. It uses a Sharp proximity sensor. It runs well when it does not sense anyting but when i put my hand near it sometimes is turns but other times it stops and the motor moves a tiny bit and then it stops.
Here is a video ..... - YouTube
Side comments
when it stops the tx and rx lights on the arduino are flashing (simmilar to when it finds an object). After a while (a minute or two... or sometimes never - have to restart it) when it continues going strait it stops blinking.
this is my code
int d1a=13;
int d2a= 12;
int s1= 10;
int d1b=11;
int d2b=8;
int sb=9;
int sensorPin = 5;
void setup () {
  pinMode (d1a, OUTPUT);
  pinMode (d2a, OUTPUT);
  pinMode (s1, OUTPUT);
  pinMode (d1b, OUTPUT);
  pinMode (d2b, OUTPUT);
  pinMode (sb, OUTPUT);
void loop () {
  int val= analogRead (sensorPin);
  Serial.println (val);
    if (val > 520) {
     analogWrite (10, 255);
digitalWrite (13 , HIGH);
digitalWrite (12, LOW);
analogWrite (9, 255);
digitalWrite (11 , HIGH);
digitalWrite (8, LOW);
delay (1500);
      analogWrite (10, 190);
analogWrite (9, 190);
digitalWrite (11 , LOW);
digitalWrite (8, HIGH);
  delay (1000);
    else {
        analogWrite (10, 200);
digitalWrite (13 ,LOW);
digitalWrite (12, HIGH);
analogWrite (9, 200);
(code tags added by moderator)
iint d1a=13;
shouldnt that be
"int d1a=13;"
Thanks... i dont know where that came from it wasnt in my actuall code... i fixed it though
oh alright, yeah im just learning so i cant help you.
Are you powering everything from the same power source ? My guess is that when the robot wants to turn one of motors to do a lot more work somits pulling too much current which drops the battery voltage causing your uno to reset - have a look at tje two links in my signature, they relate to servos but its the same principle and solution.
Duane B
rcarduino.blogspot.com
Good idea.. I will look into it
