Hello i am working on a school project: i want make cartography of region with airplane.
I want to buy the EAGLE EYE gimbal with BaseCam SimpleBGC 32-bit controller.
The CANON 600D has to be gyrostabilized. Pictures need to be georeferenced.
In this message there are 3 pictures of the system i want to construct. Can you help me to answer these questions (in picture3)?
Questions:
a) What is the langage of programmation of the SYSTEM_2 ?
b) Could this language (of system_2) be compatible with System_1 (Arduinocard for exemple)?
c) Is it possible that system_1 and system_2 communicate together with the same informatic langage?
d) Wich informations can be extracted from the system_2?
e)Is it possible to extract from system_2 the « 3 angles positions » of plateform and « magnetometers informations » and is it possible to read these informations with system_1?
f) Can system_1 command the system_2?
g) Is it possible to connect system_2 to LABVIEW and to read informations of system_2 with LABVIEW computer software?
Looks like you changed the questions a little as you went, I've copied the latest below:
a)Which model of Arduino card or PC card (=SYSTEM_1) do you advice me to buy?
b)Which model of GPS is compatible with this model of Arduino card (choosen in question a.) ( accuracy required of GPS poistion about 2.5 meters)?
c)What is the langage of programmation of the SYSTEM_1 (I want to use an ARDUINO card) and system_2?
d)Could his language (of system_1) be compatible with System_2 (BaseCam SimpleBGC 32-bit controller)?
e)Is it possible that system_1 and system_2 communicate together with the same informatic langage? Can informations be extracted from the system_2 and be sent to system_1?
g) Is it possible to connect system_1 (and also system_2) to LABVIEW ? Is it possible to read informations of system_1 and system_2 with LABVIEW computer software?
h)Is it possible to extract from system_2 the « 3 angles positions » of plateform and « magnetometers informations » and is it possible to read these informations with system_1?
