Arduino CC3000 websocket client
Hello guys,
I am working on a project in which Arduino is supposed to send receive data from remote server using websocket connection. I have used the reference code from this git repository. I have modified the client code to work with the Arduino_CC3000 library.
I am facing the problem to connect to eho.websocket.org as per the demo websocketclient.ino example.
it is not receiving any response from the server.
I am stuck and not getting the way to get out of it.
here is my code which i have modified
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include <WebSocketClient.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "UNSTOPPABLE"           // cannot be longer than 32 characters!
#define WLAN_PASS       "8878333344"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS  3000      // Amount of time to wait (in milliseconds) with no data
// received before closing the connection.  If you know the server
// you're accessing is quick to respond, you can reduce this value.
// What page to grab!
#define WEBSITE      "www.websocket.org"
//#define WEBPAGE      "/testwifi/index.html"
// Here we define a maximum framelength to 64 bytes. Default is 256.
#define MAX_FRAME_LENGTH 64
// Define how many callback functions you have. Default is 1.
#define CALLBACK_FUNCTIONS 1
Adafruit_CC3000_Client www;
WebSocketClient webSocketClient;
 @brief  Sets up the HW and the CC3000 module (called automatically
 on startup)
uint32_t ip;
void setup(void)
  Serial.println(F("Hello, CC3000!\n"));
  Serial.print("Free RAM: ");
  Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  // Optional SSID scan
  // listSSIDResults();
  Serial.print(F("\nAttempting to connect to "));
  Serial.println(WLAN_SSID);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  ip = 0;
  // Try looking up the website's IP address
  Serial.print(WEBSITE);
  Serial.print(F(" -> "));
  while (ip == 0) {
    if (! cc3000.getHostByName(WEBSITE, &ip)) {
      Serial.println(F("Couldn't resolve!"));
  cc3000.printIPdotsRev(ip);
  // Optional: Do a ping test on the website
  Serial.print(F("\n\rPinging ")); cc3000.printIPdotsRev(ip); Serial.print("...");
   replies = cc3000.ping(ip, 5);
   Serial.print(replies); Serial.println(F(" replies"));
  /* Try connecting to the website.
   Note: HTTP/1.1 protocol is used to keep the server from closing the connection before all data is read.
  www = cc3000.connectTCP(ip, 80);
  if (www.connected()) {
    /*    www.fastrprint(F("GET "));
     www.fastrprint(WEBPAGE);
     www.fastrprint(F(" HTTP/1.1\r\n"));
     www.fastrprint(F("Host: ")); www.fastrprint(WEBSITE); www.fastrprint(F("\r\n"));
     www.println();*/
  else {
    Serial.println(F("Connection failed"));
    return;
  Serial.println(F("-------------------------------------"));
  /* Read data until either the connection is closed, or the idle timeout is reached. */
  /*  unsigned long lastRead = millis();
   while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
   while (www.available()) {
   char c = www.read();
   Serial.print(c);
   www.close();
   Serial.println(F("-------------------------------------"));*/
  /* You need to make sure to clean up after yourself or the CC3000 can freak out */
  /* the next time your try to connect ... */
  /*  Serial.println(F("\n\nDisconnecting"));
   cc3000.disconnect();*/
  // Handshake with the server
  webSocketClient.path = "/echo.html";
  webSocketClient.host = WEBSITE;
  if (webSocketClient.handshake(www)) {
    Serial.println("Handshake successful");
  else {
    Serial.println("Handshake failed.");
    while(1) {
      // Hang on failure
void loop(void)
  String data;
    /*   data = webSocketClient.getData();
     if (data.length() > 0) {
     Serial.print("Received data: ");
     Serial.println(data);
    // capture the value of analog 1, send it along
    pinMode(1, INPUT);
    data = String(analogRead(1));
    webSocketClient.sendData(data);
  else {
    Serial.println("Client disconnected.");
    while (1) {
      // Hang on disconnect.
  // wait to fully let the client disconnect
  delay(3000);
 @brief  Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
  uint32_t index;
  uint8_t valid, rssi, sec;
  char ssidname[33];
  if (!cc3000.startSSIDscan(&index)) {
    Serial.println(F("SSID scan failed!"));
    return;
  Serial.print(F("Networks found: "));
  Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : "));
    Serial.print(ssidname);
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
  cc3000.stopSSIDscan();
 @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: "));
    cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: "));
    cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: "));
    cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: "));
    cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: "));
    cc3000.printIPdotsRev(dnsserv);
    return true;
Here what I get when i try to connect to the echo.websocket.org
Hello, CC3000!
Free RAM: 581
Initializing...
Attempting to connect to UNSTOPPABLE
Connected!
Request DHCP
IP Addr: 192.168.1.3
Netmask: 255.255.255.0
Gateway: 192.168.1.1
DHCPsrv: 192.168.1.1
DNSserv: 192.168.1.1
www.websocket.org -> 174.129.224.73-------------------------------------
Client connected
Sending websocket upgrade headers
Analyzing response headers
It hangs on analyzing response. please someone help me with this. I need guidance.
