Arduino CC3000 Wifi lagging
Hi all! So I have used a 3V and 5V circuit, I also went from 8Mhz Arduino to 16Mhz Arduino all with the same result. After a few connections, the system seems to stop working for about 20-30 seconds, and then I can post data again. Maybe there is something in my code stopping the CC3000 from working properly? I upgraded the firmware as well to make sure I am up to date.
I have an XBee receiving packets, then posting the packets online to Dweet.io.
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include <XBee.h>
#include <SoftwareSerial.h>
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
ZBRxResponse rx = ZBRxResponse();
ModemStatusResponse msr = ModemStatusResponse();
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS,
ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIV2);
#define WLAN_SSID       "SSID"
#define WLAN_PASS       ""
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define thing_name  "SomeName"
char pay0;
char pay1;
uint32_t ip;
void setup(void)
  xbee.setSerial(Serial);
  if (!cc3000.begin())
    while(1);
  cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
  while (!cc3000.checkDHCP())
    delay(100);
void loop(void)
  readXbee();
  sendDweet();
void sendDweet(){
  uint32_t ip = 0;
  while  (ip  ==  0)  {
    if  (!  cc3000.getHostByName("www.dweet.io", &ip))  {
  cc3000.printIPdotsRev(ip);
  if(!cc3000.checkConnected()){while(1){}}
  Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
  if (client.connected()) {
    client.fastrprint(F("GET /dweet/for/"));
    client.print(thing_name);
    client.fastrprint(F("?LowHex="));
    client.print(rx.getRemoteAddress64().getMsb(), HEX);
    client.fastrprint(F("&HighHex="));
    client.print(rx.getRemoteAddress64().getLsb(), HEX);
    client.fastrprint(F("&Pay0="));
    client.print(pay0);
    client.fastrprint(F("&Pay1="));
    client.print(pay1);
    client.fastrprintln(F(" HTTP/1.1"));
    client.fastrprintln(F("Host: dweet.io"));
    client.fastrprintln(F("Connection: close"));
    client.fastrprintln(F(""));
    return;
void readXbee(){
  xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {
      if (xbee.getResponse().getApiId() == ZB_RX_RESPONSE) {
        xbee.getResponse().getZBRxResponse(rx);
         for (int i = 0; i < rx.getDataLength(); i++) {
          if (i == 0){
            pay0 = rx.getData()[i];
          if (i == 1){
            pay1 = rx.getData()[i];
If this was my project I would add some Serial.print() statements so I could see where it's at when it gets stuck.
Why have you a delay between readXbee() and sendDweet() ?
Does the call to cc3000.getHostByName() fail some of the time ?
Your code does not seem to allow for the possibility of a valid readXbee() followed by a failed sendDweet. Neither does it seem to allow for a failed readXbee().
...R
Originally I had all the checks in serial.print format that the template code suggests and you are right. Most if not all the hangups were on getHostByName.
This is a real Beta build, I will add all the if/then case type scenario's later. In a perfect world there are no fail reads :wink: haha
brolly759:
I think you need to allow for web access to be very unpredictable.
...R
The problem is, while in this "unpredictable" state, I lose packets if they start coming in from xBee.
brolly759:
If the fault is somewhere in "the cloud" there is not much you can do about it.
Maybe you could store the packets and send them a little later - but you can't store much on an Arduino.
...R
