arduino cdi
hi guys
i'm quite a newbie, i have arduino from about 5 months and it is my first software axperience, i'm a nautical mechanic
i'm working on a arduino cdi for quite hold gasoline engines that still have mechanic ignition sistem to swap them to elecrtonic ignition
here the code wich i'm working on right now, it has some bugs but not a lot and not heavy... something isn't how it should be especially the lighting coils control but i'm working on a simblpe breadboard with just a little pc fan, hall sensor, magnet and 2 leds as stroboscopic light to check what the board is doing.... and it works!!
so i want to show it to the community to ask suggestions also if i have already posted it on the italian forum
i'm thinking on connect my raspberry via I2C with the arduino to show engine statistic in real time and change them
map() is just fon now, i will improve a sistem who will leave the user free to change the timing with more flexibility as the real cdi
#include <StopWatch.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(11, 10, 7, 6, 5, 4);      //pin lcd
const byte led1 = 13;    // cilindri 1 e 4
const byte led2 = 12;    // cilindri 2 e 3
const byte pin2 = 2;     // interrupt startt
const byte pin3 = 3;     // interrupt stopp
volatile int statestartt = HIGH;    // stato normale startt
volatile int statestopp=HIGH;       // stato normale stopp
StopWatch sw_micros(StopWatch::MICROS);    // timer durata dente
StopWatch sw_micros1(StopWatch::MICROS);   // timer attesa 1 e 4
StopWatch sw_micros2(StopWatch::MICROS);   // timer attesa 2 e 3
long time = 0;           //valore durata dente microsecondi
long ritardo = 0;       //gradi ritardo da fine dente
long tritardo1 = 0;      //valore durata ritardo in microsecondi 1 e 4
long tritardo2 = 0;      //valore durata ritardo in microsecondi 2 e 3
long rpm = 0;             //numero giri
int gradidente = 40;     //ampiezza dente in gradi
  Serial.begin(9600);     //comunicazione seriale
  lcd.begin(16, 2);       // comunicazione lcd
  pinMode(led1, OUTPUT);  //bobina 1 e 4
  pinMode(led2, OUTPUT);  //bobina2 e 3
  pinMode(pin2, INPUT_PULLUP);
  pinMode(pin3, INPUT_PULLUP);
  attachInterrupt(0, startt, FALLING);   //interrupt in inizio dente
  attachInterrupt(1, stopp, RISING);     //interrupt fine dente
  //se il dente è iniziato
  if(statestartt == LOW){
    sw_micros.start();//inizia a contare durata dente
    statestartt=HIGH;// reimposta startt
  //se il dente è finito
  if(statestopp == LOW) {
    time=sw_micros.elapsed();                  //memorizza durata dente
    sw_micros1.start();                        //inizia a contare da fine dente per 1 e 4
    sw_micros2.start();                        //inizia a contare da fine dente per 2 e 3
    //Serial.println(time);                      //stampa durata dente
    statestopp = HIGH;                         //reimposta stopp
    sw_micros.reset();                          //azzera timer durata dente
     rpm=60000000/((time/gradidente)*360);      //calcolo rpm
    ritardo=map(rpm, 600, 1800, 70, 100);       //determina ritardo
    ritardo = constrain(ritardo, 70, 100);      // mantieni il ritardo entro l'intervallo prestabilito
     Serial.print(rpm);                       //stampo rpm
    Serial.print("          ");
    Serial.println(ritardo);
    lcd1();                                    //void lcd
    tritardo1=(time/gradidente)*ritardo;       //calcola durata ritardo in microsecondi per 1 e 4
    tritardo2=(time/gradidente)*(ritardo+180); //calcola durata ritardo in microsecondi per 2 e 3
  //se il tempo che è passato dalla fine del dente è maggiore della durata del ritardo
  if(sw_micros1.elapsed() >= tritardo1){
    sw_micros1.reset();                        //azzera timer ritardo
    digitalWrite(led1, HIGH);                  //accendi led
    delayMicroseconds(500);
    digitalWrite(led1, LOW);                    //spegni led
  if(sw_micros2.elapsed()>=tritardo2){
    sw_micros2.reset();                          //azzera timer ritardo
    digitalWrite(led2, HIGH);                    //accendi led
    digitalWrite(led2, LOW);                      //spegni led
} // End Loop
void startt()//interrupt startt
  statestartt = !statestartt;  //inverti startt
void stopp()//interrupt stopp
  statestopp = !statestopp;    //inverti stopp
void lcd1(){
  lcd.setCursor(0, 0);              //riga nomi
  lcd.print("Rpm     BTDC");        // stampa nomi
 lcd.setCursor(0, 1);              //riga dati
  lcd.print(rpm);                   //stampa rpm
  lcd.setCursor(4, 1);
  lcd.print("    ");
  lcd.setCursor(9, 1);
  lcd.print(ritardo);              //stampa ritardo
Thanks for posting the code, I'll be testing it latter.
I've noticed that the arduino is very sensitive to electrical noise causing unstable operation. Be very careful with sheilding and control of the induction coils. Even a 5 volt coil can produce kickback approaching 100V or more. Optical isolation might be a good idea.
Find some good IGBT to drive the coils
Have fun and good luck
