Arduino CLI not working
Hi -
I’ve been looking at this page because I could also benefit from a command line interface. That way I can use my IDE of choice.
However, no matter which command I try, the Arduino IDE will never do anything. It will start the software with a blank sketch. I have v1.6.3.
Do you know what I am doing wrong?
Consider this command:
arduino.exe c:/[path/blink.ino
It never opens the Sketch like the manual says.
Thanks a lot,
Eric
Hello,
Works for me on Windows 8:
arduino C:/Users/xxx/Documents/Arduino/sketch/sketch.ino
Maybe you have spaces in the path? Add double quotes then
arduino "C:/Users/xx xx/Documents/Arduino/sketch/sketch.ino"
"C:\Program Files (x86)\Arduino\arduino.exe" "D:\desktop\spoon\spoon.ino"
loads up the file spoon.ino just fine for me. as does:
arduino.exe D:\desktop\spoon\spoon.ino
(from C:\Program Files (x86)\Arduino>)
are you using the full path for the ino file? it doesn't work unless you use the full path for the INO file.
Hi thanks,
The problem I was having was that I ran the command from another directory (the sketch folder).
When I change the directory to c:\Program Files (x86)\Arduino it all works fine!
Thanks for the reply.
Small tip:
If you want to get the same console output as the Arduino IDE, using --verbose is not enough. Calling arduino_debug.exe with the same CLI commands does however give the same output.
