Arduino-cli on nixos
I am trying to use arduino-cli on NixOS, but, after giving
arduino-cli update
the command to list the boards is empty:
arduino-cli board listall
So I am wondering how the CLI detects the correct host platform, since I suppose this is a host (NixOS) configuration fault.
Thank you,
regards
Hi @fstefanni. Have you used arduino-cli core install to install any Arduino boards platforms?
From the command documentation:
https://arduino.github.io/arduino-cli/latest/commands/arduino-cli_board_listall/
List all boards that have the support platform installed.
So it is expected that this command will produce an empty list of boards if you haven't installed any platforms.
I re-checked carefully the commands, and I discovered that I was giving a wrong parameter to arduino-cli core install... so solved.
Thank you for the support.
Regards
You are welcome. I'm glad it is working now.
Regards,
Per
