Arduino client-server post request
Hello everyone,
I am testing a custom API using ESP8266 to send and fetch data from it. Everything looks okay in the code but I always received Bad request error. Here is the code:
#include <ESP8266WiFi.h>
const char* ssid = "iottollgate";
const char* password = "iot2017/2018";
const char* host = "https://transformer-monitoring.herokuapp.com";
const char* path = "POST /api?c=20&l=55&t=87&v=78&n=1 HTTP/1.1\r\nHost: https://transformer-monitoring.herokuapp.com\r\n\r\n";
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println(" connected");
  WiFiClient client;
  Serial.printf("\n[Connecting to %s ... ", host);
  if (client.connect(host, 80))
    Serial.println("connected]");
    Serial.println("[Sending a request]");
    client.print(String(path));
    Serial.println("Path:"+String(path));
    Serial.println("[Response:]");
    while (client.connected())
      if (client.available())
        String line = client.readStringUntil('\n');
        Serial.println(line);
    client.stop();
    Serial.println("\n[Disconnected]");
    Serial.println("connection failed!]");
    client.stop();
  delay(5000);
host should be transformer-monitoring.herokuapp.com
https is the protocol and I don't think you can issue a secure http request (over TLS) that way. You would need to either use website's fingerprint, or to use client.setInsecure()
https in the host is the cause of the problem as you pointed out. I removed it and the request was successful. This actually gave me serious headache for days and in fact, I destroyed an ESP32 dev kit in the process.
Thanks very much for this priceless help.
OK if that works it means your server is not HTTPS but just HTTP
