Arduino clock
Hello guys, so I have this code for displaying the time on a rgb 16x2 LCD screen. Everything works fine except that it gets stuvk on displaying sunday. I read through the code and couldn't find any problems... Any sugestions ? Here is the code:
// Connections:
// LCD pin 1 to Arduino GND
// LCD pin 2 to Arduino 5v
// LCD pin 3 (Contrast) to GND
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pin 16 to Arduino GND
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
//Tested with DS1307 Breakout from Sparkfun
//pin SDA to Arduino Analog pin 4
//pin SCL to Arduino Analog pin 5
//pin GND to Arduino GND
//pin VCC to Arduino 5v
#include <Wire.h>
#define DS1307_I2C_ADDRESS 0x68
#include <LiquidCrystal.h> // we need this library for the LCD commands
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13; // pin 13 will control the backlight
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers
void setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.send(0);
Wire.send(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.send(decToBcd(minute));
Wire.send(decToBcd(hour));
Wire.send(decToBcd(dayOfWeek));
Wire.send(decToBcd(dayOfMonth));
Wire.send(decToBcd(month));
Wire.send(decToBcd(year));
Wire.send(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.send(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
*second = bcdToDec(Wire.receive() & 0x7f);
*minute = bcdToDec(Wire.receive());
*hour = bcdToDec(Wire.receive() & 0x3f); // Need to change this if 12 hour am/pm
*dayOfWeek = bcdToDec(Wire.receive());
*dayOfMonth = bcdToDec(Wire.receive());
*month = bcdToDec(Wire.receive());
*year = bcdToDec(Wire.receive());
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
Wire.begin();
// Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call.
second = 0;
minute = 42;
hour = 9;
dayOfWeek = 1;
dayOfMonth = 3;
month = 10;
year = 10;
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
lcd.begin(16, 2); // tells Arduino the LCD dimensions
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
lcd.clear(); // clear LCD screen
lcd.setCursor(0,0);
lcd.print(" ");
lcd.print(hour, DEC);
lcd.print(":");
if (minute<10)
lcd.print("0");
lcd.print(minute, DEC);
lcd.print(":");
if (second<10)
lcd.print("0");
lcd.print(second, DEC);
lcd.setCursor(0,1);
lcd.print(" ");
switch(dayOfWeek){
case 1:
lcd.print("Sun");
case 2:
lcd.print("Mon");
case 3:
lcd.print("Tue");
case 4:
lcd.print("Wed");
case 5:
lcd.print("Thu");
case 6:
lcd.print("Fri");
case 7:
lcd.print("Sat");
lcd.print(" ");
lcd.print(month, DEC);
lcd.print("/");
lcd.print(dayOfMonth, DEC);
lcd.print("/20");
lcd.print(year, DEC);
That code really takes the prize. For worst code posted all week. The only thing going for it is that it IS in a code box.
Tools + Auto Format would REALLY help.
What does "gets stuvk (stuck?) on displaying sunday ("Sun"?)" mean?
You have Serial.begin() in setup(), but nary a Serial.print() in sight. Why not?
You may think PaulS is being a little harsh (and maybe he is) but the essence of what he is saying is true.
I'm not going to replicate your project (even if I knew what components you were using and how you had them wired up) so your comment that it gets 'stuvk' isn't the most helpful. You need to be more specific in what is happening. And, as PaulS has hinted, put some Serial.print statements in your code so you can see what is happening.
And, when you get a problem, auto-format your code using Tools -> Auto Format. This indents all your code for you and often you can see that something isn't where you though it was (in the process). Not to mention making it easier for other forum users to read if you need help!
@begin_to_program:
Have you changed the number for dayOfWeek? (For Sunday, use 1; for Monday, use 2; etc.)
From looking at the code, it seems that's what you need to do.
If you don't want to put in the day of the week manually, well, I've written a function just for you (any anyone in your situation):
byte calcDayOfWeek (byte y, byte m, byte d) {
  // Old mental arithmetic method for calculating day of week
  // adapted for Arduino, for years 2000~2099
  // returns 1 for Sunday, 2 for Monday, etc., up to 7 for Saturday
  // for "bad" dates (like Feb. 30), it returns 0
  // Note: input year (y) should be a number from 0~99
  if (y > 99) return 0; // we don't accept years after 2099
  // we take care of bad months later
  if (d < 1) return 0; // because there is no day 0
  byte w = 6; // this is a magic number (y2k fix for this method)
  // one ordinary year is 52 weeks + 1 day left over
  // a leap year has one more day than that
  // we add in these "leftover" days
  w += (y + (y >> 2));
  // correction for Jan. and Feb. of leap year
  if (((y & 3) == 0) && (m <= 2)) w--;
  // add in "magic number" for month
  switch (m) {
    case 1:  if (d > 31) return 0; w += 1; break;
    case 2:  if (d > ((y & 3) ? 28 : 29)) return 0; w += 4; break;
    case 3:  if (d > 31) return 0; w += 4; break;
    case 4:  if (d > 30) return 0; break;
    case 5:  if (d > 31) return 0; w += 2; break;
    case 6:  if (d > 30) return 0; w += 5; break;
    case 7:  if (d > 31) return 0; break;
    case 8:  if (d > 31) return 0; w += 3; break;
    case 9:  if (d > 30) return 0; w += 6; break;
    case 10: if (d > 31) return 0; w += 1; break;
    case 11: if (d > 30) return 0; w += 4; break;
    case 12: if (d > 31) return 0; w += 6; break;
    default: return 0;
  // then add day of month
  w += d;
  // there are only 7 days in a week, so we "cast out" sevens
  while (w > 7) w = (w >> 3) + (w & 7);
  return w;
