Arduino Cloud IoT Thing to thing sync not working
Hello, I am currently working on a project in which 2 Generic ESP8285 modules need to communicate, however after trying to sync variables in the Cloud Thing menu, they won't sync at all. Why is that?
Hello @marius12323
Are you sure that both boards are connected to the cloud? How do you check if the variables are synching?
Hello! I am sure as the boards show in the serial monitor that they succesfully connected, and I check that the variables are syncing via the Dashboard..
How do you set the value of one of the variables? Can you send to me privately (f.mirabito@arduino.cc) your thing IDs, so I can check on the backend?
I use an integer variable that changes its value between 0 and 1 whenever a condition that I set is met. In the second Thing I set a new integer variable that I try to sync with the first one, however, their values are not matching at all..
