Arduino code do not detect micro sd card
Hi, I have bougth two module to read/write micro SD card, and I use a simple code found in arduino pages, but it seems that SD card is not found.
Can someone help me?
Code:
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print(“Initializing SD card…”);
if (!SD.begin(4)) {
Serial.println(“initialization failed!”);
return;
Serial.println(“initialization done.”);
I allways got “initialization failed!” as result.
Connections done:
GND GND
5V 5V
CS 4 o 10
SCK 13
MOSO 12
MOSI 11
Thanks for your answers. :wink:
Are the cards formatted?
Paul
how about you go to arduino IDE,
File > example > SD > CardInfo , and upload that code?
remember to change the pin number according to ur connection
Hi
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
mbl:
GND GND
5V 5V
CS 4 o 10
SCK 13
MOSO 12
MOSI 11
What is 'CS 4 o 10' ?
Which pin do you physically have connected to the SD CS ?
Also, since you haven't mentioned what 'module' you are using- SD cards only work with 3.3V, if your modules don't have level shifting you'll be killing your SD cards.
