Hello, I am a newbie to Arduino. So happy to be on this forum between you intellectual people. Below is my arduino code generated by Firefly (Rhino Grasshopper Plugin). When I try to upload it to my board it generates series of errors. Can somebody please look into the matter and guide me to the correct path
Firefly Code Generator by Andy Payne
Copyright 2011 All Rights Reserved
Code Generated on 07/30/2021 12:38:09
Special thanks to Panagiotis Michalatos.
For more information visit: www.fireflyexperiments.com
#include "FFCasts.h"
#include <Servo.h>
//******************* Begin Function Definitions *******************
//Remap Number Function: Remap a value into a new numeric domain.
double Remap_Numbers(double x, Interval _in, Interval _out) {
return (x - _in.t0) * (_out.t1 - _out.t0) / (_in.t1 - _in.t0) + _out.t0;
//Multiplication Function: Multiply two numbers.
inline double Multiplication(double _v1, double _v2){
return _v1 * _v2;
//Constrain Function: Constrains a number to a specific numeric range.
double Constrain(double _v1, Interval _in){
double _min, _max, result;
if (_in.t0 < _in.t1){
_min = _in.t0;
_max = _in.t1;
}else{
_min = _in.t1;
_max = _in.t0;
if (_v1 < _min){
result = _min;
}else if (_v1 > _max){
result = _max;
}else{
result = _v1;
}return result;
double smoothlist_0[1];
int smoothindex_0 = 0;
double smoothtotal_0 = 0.0;
//Smoothing Function: Smooth (or average) an incoming value based on (N) number of samples.
double Smoothing_Moving_Average(double _v1, int _n, double *_list, int *_index, double *_total){
*_total -= _list[*_index];
*_total += _v1;
_list[*_index] = _v1;
(*_index)++;
if (*_index >= _n) *_index = 0;
return *_total/(double)_n;
//******************** End Function Definitions ********************
Servo servo-1;
int smi;
for(smi = 0; smi < 1; ++smi) {
smoothlist_0[smi] = 0.0;
servo-1.attach(-1);
digitalWrite(-1, Multiplication(Remap_Numbers(Analog_Pin_0,Interval(100,250),Interval(1,0)),0));
digitalWrite(-1, Multiplication(Remap_Numbers(Analog_Pin_0,Interval(100,250),Interval(0,1)),0));
servo-1.write(Smoothing_Moving_Average(Remap_Numbers(Constrain(Analog_Pin_0,Interval(100,250)),Interval(100,250),Interval(85,99)),1, smoothlist_0, &smoothindex_0, &smoothtotal_0));
struct Interval {
Interval(double _t0, double _t1) {
t0=_t0;
t1=_t1;
Interval(double _t1) {
t0=0.0;
t1=_t1;
Interval(const Interval &_i) {
t0=_i.t0;
t1=_i.t1;
double t0, t1;
Errors
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Uno"
Firefly:59:12: error: expected initializer before '-' token
Servo servo-1;
D:\SCET\Academics\5th Year\Research\Firefly\Firefly.ino: In function 'void setup()':
Firefly:66:3: error: 'servo' was not declared in this scope
servo-1.attach(-1);
D:\SCET\Academics\5th Year\Research\Firefly\Firefly.ino:66:3: note: suggested alternative: 'Servo'
servo-1.attach(-1);
Servo
Firefly:66:9: error: unable to find numeric literal operator 'operator""attach'
servo-1.attach(-1);
D:\SCET\Academics\5th Year\Research\Firefly\Firefly.ino: In function 'void loop()':
Firefly:70:49: error: 'Analog_Pin_0' was not declared in this scope
D:\SCET\Academics\5th Year\Research\Firefly\Firefly.ino:70:49: note: suggested alternative: 'analogWrite'
analogWrite
Firefly:72:3: error: 'servo' was not declared in this scope
D:\SCET\Academics\5th Year\Research\Firefly\Firefly.ino:72:3: note: suggested alternative: 'Servo'
Servo
Firefly:72:9: error: unable to find numeric literal operator 'operator""write'
Multiple libraries were found for "Servo.h"
Used: C:\Users\Dell\Documents\Arduino\libraries\Servo
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries\Servo
exit status 1
option enabled in File -> Preferences.
