Hi ,
I am creating on Arduino joystick for my RC car but getting error while verifying
here is the code
//Transmitter code
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
const uint64_t pipeOut = 0xE9E8F0F0E1LL;
RF24 radio(7, 8);
struct Signal {
byte throttle;
byte pitch;
byte roll;
byte yaw;
Signal data;
void ResetData()
data.throttle = 127;
data.pitch = 127;
data.roll = 127;
data.yaw = 127;
//Start everything up
radio.begin();
radio.openWritingPipe(pipeOut);
radio.stopListening();
ResetData();
int mapJoystickValues(int val, int lower, int middle, int upper, bool reverse)
val = constrain(val, lower, upper);
if ( val < middle )
val = map(val, lower, middle, 0, 128);
val = map(val, middle, upper, 128, 255);
return ( reverse ? 255 - val : val );
data.throttle = mapJoystickValues( analogRead(A0), 12, 524, 1015, true );
data.roll = mapJoystickValues( analogRead(A1), 12, 524, 1020, true );
data.pitch = mapJoystickValues( analogRead(A2), 12, 524, 1020, true );
data.yaw = mapJoystickValues( analogRead(A3), 12, 524, 1020, true );
radio.write(&data, sizeof(Signal));
Here is the error
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino:14:8: error: expected initializer before 'data'
Signal data;
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino: In function 'void ResetData()':
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino:17:1: error: 'data' was not declared in this scope
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino:17:1: note: suggested alternative: 'atan'
atan
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino: In function 'void loop()':
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino:43:1: error: 'data' was not declared in this scope
C:\Users\Hacker\AppData\Local\Temp.arduinoIDE-unsaved2023527-1388-14fva2y.0uun\sketch_jun27a\sketch_jun27a.ino:43:1: note: suggested alternative: 'atan'
atan
exit status 1
Compilation error: expected initializer before 'data'
