Hello Community,
I'm building a code that takes input from several sensors and the result to display on my sign that has about 100 WS2812 LEDs. I have problems with the code. So here is the situation so far.
I have a DHT11 sensor and a LDR. humidity and HeatIndex values are taken and mapped to a certain color so that its reflected on my sign. And brightness is changed according to the values from the LDR. For these changes in color and brightness I used the map() function but, for a smooth fade used the idea from "Hans Jørgen" (Natural-Nerd/sound_reactive.ino at master · hansjny/Natural-Nerd · GitHub) and managed to play around with the values. the code is 270+ lines. so here is my code:
#include "DHT.h"
#include "FastLED.h"
#include <math.h>
#define DHTPIN 8
#define DHTTYPE DHT11 // DHT 11
#define NUM_LEDS_1 60
#define LED_PIN 10
#define NUM_LEDS_2 21
#define LED_PIN_2 11
#define UPDATES_PER_SECOND 100
int old_temp_color = 0;
int old_humd_color = 0;
int old_brightness = 200;
DHT dht(DHTPIN, DHTTYPE);
CRGB leds_1[NUM_LEDS_1];
CRGB leds_2[NUM_LEDS_2];
/*for sound sensor*/
const int sampleWindow = 50; //sample window width in ms(50ms =20Hz)
unsigned int sample;
/*values for temperature and fade*/
int i;
void fade_between_temp(int a, int b, CRGB leds_1[NUM_LEDS_1], int del, int bright);
void set_definite_temp(int a, CRGB leds_1[NUM_LEDS_1], int bright);
/*values for humidity fade*/
int k;
void fade_between_humd(int e, int f, CRGB leds_2[NUM_LEDS_2], int del, int bright);
void set_definite_humd(int e, CRGB leds_2[NUM_LEDS_2], int bright);
/*values and functions for brightness fade*/
int j;
void fade_between_brightness(int c, int d, CRGB leds_1[NUM_LEDS_1], CRGB leds_2[NUM_LEDS_2], int del, int color1, int color2);
void set_definite_brightness(int c, CRGB leds_1[NUM_LEDS_1], CRGB leds_2[NUM_LEDS_2], int color1, int color2);
/*for LDR*/
int ldr = A0;//Set A0(Analog Input) for LDR.
int ldr_raw = 0;
/*for motion sensor*/
int PIR = 2;
unsigned long myTime;
unsigned long finish;
Serial.println("starting the system");
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds_1, NUM_LEDS_1);
FastLED.addLeds<WS2812, LED_PIN_2, GRB>(leds_2, NUM_LEDS_2);
for (int x = 0, y = 0; (x < NUM_LEDS_1) && (y < NUM_LEDS_2); x++, y++) {
leds_1[x] = CHSV(255, 0, old_brightness);
leds_2[y] = CHSV(255, 0, old_brightness);
FastLED.show();
delay(2000);
/*temperature and humidity sensor*/
dht.begin();
// /*PIR sensor*/
// pinMode(PIR, INPUT); // initialize sensor as an input
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
float f = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F("Humidity: "));
Serial.println(h);
Serial.print(F("% Temperature: "));
Serial.println(t);
Serial.println(F("°C "));
Serial.println(f);
Serial.print(F("°F Heat index: "));
Serial.println(hic);
if (hic < 18) {
hic = 18;
if (hic > 35) {
hic = 35;
int new_temp_color = map(hic, 18, 35, 95, 0);
Serial.print(" new_temp_color = ");
Serial.println(new_temp_color);
Serial.print(" old_temp_color = ");
Serial.println(old_temp_color);
if (new_temp_color < 0) {
new_temp_color = 0;
if (new_temp_color > 95) {
new_temp_color = 95;
fade_between_temp(old_temp_color, new_temp_color, leds_1, 100, old_brightness );
old_temp_color = new_temp_color;
if (h < 10) {
hic = 1;
if (h > 85) {
hic = 85;
int new_humd_color = map(h, 10, 85, 135, 165);
Serial.print(" new_humd_color = ");
Serial.println(new_humd_color);
Serial.print(" old_humd_color = ");
Serial.println(old_humd_color);
if (new_humd_color < 135) {
new_humd_color = 135;
if (new_humd_color > 165) {
new_humd_color = 165;
fade_between_humd(old_humd_color, new_humd_color, leds_2, 100, old_brightness );
old_humd_color = new_humd_color;
/*LDR sensor*/
ldr_raw = analogRead(ldr);//Reads the Value of LDR(light).
int new_brightness = map(ldr_raw, 0, 1000, 255, 50);
Serial.print(" new brightness = ");
Serial.println(new_brightness);
Serial.print(" old brightness = ");
Serial.println(old_brightness);
fade_between_brightness(old_brightness, new_brightness, leds_1, leds_2, 100, new_temp_color, new_humd_color);
old_brightness = new_brightness;
// /*pir sensor*/
// delay(500);
// Serial.println("HIHI");
// //Wait a few seconds between measurements
// int val = digitalRead(PIR); // read sensor value
// if (val == HIGH) { // check if the sensor is HIGH
// Serial.println("motion detected");
// myTime = millis();
// finish = myTime + 10000;
// rainbow();
// while (millis() != finish) /* spin your wheels */ ;
/*for temp color fade*/
void fade_between_temp(int a, int b, CRGB leds_1[NUM_LEDS_1], int del, int bright) {
int i, j, steps = 100;
double dsteps = 100.0;
double s1, tmp1;
s1 = double((b - a)) / dsteps;
tmp1 = a;
for (i = 0; i < steps; i++) {
tmp1 += s1;
for (j = 0; j < NUM_LEDS_1; j++)
leds_1[j] = CHSV((int)round(tmp1), 255, bright);
FastLED.show();
delay(del);
set_definite_temp(b, leds_1, bright);
void set_definite_temp(int a, CRGB leds_1[NUM_LEDS_1], int bright) {
int i;
for (i = 0; i < NUM_LEDS_1; i++)
leds_1[i] = CHSV(a, 255, bright);
FastLED.show();
/*for humd color fade*/
void fade_between_humd(int e, int f, CRGB leds_2[NUM_LEDS_2], int del, int bright) {
double s1, humd1;
s1 = double((f - e)) / dsteps;
humd1 = e;
humd1 += s1;
for (j = 0; j < NUM_LEDS_2; j++)
leds_2[j] = CHSV((int)round(humd1), 255, bright);
FastLED.show();
delay(del);
set_definite_humd(f, leds_2, bright);
void set_definite_humd(int e, CRGB leds_2[NUM_LEDS_2], int bright) {
int i;
for (i = 0; i < NUM_LEDS_2; i++)
leds_2[i] = CHSV(e, 255, bright);
FastLED.show();
/*for brightness fade*/
void fade_between_brightness(int c, int d, CRGB leds_1[NUM_LEDS_1], CRGB leds_2[NUM_LEDS_2], int del, int color1, int color2) {
int j, k, l, steps = 100;
double s1, bright1;
s1 = double((d - c)) / dsteps;
bright1 = c;
for (j = 0; j < steps; j++) {
bright1 += s1;
for (k = 0, l = 0; (k < NUM_LEDS_1) && (l < NUM_LEDS_2); k++, l++)
leds_1[k] = CHSV(color1, 255, (int)round(bright1));
leds_2[l] = CHSV(color2, 255, (int)round(bright1));
FastLED.show();
delay(del);
set_definite_brightness(d, leds_1, leds_2, color1, color2);
void set_definite_brightness(int c, CRGB leds_1[NUM_LEDS_1], CRGB leds_2[NUM_LEDS_2], int color1, int color2) {
int j, k;
for (j = 0, k = 0; (j < NUM_LEDS_1) && (k < NUM_LEDS_2); j++, k++)
leds_1[j] = CHSV(color1, 255, c);
leds_2[k] = CHSV(color2, 255, c);
FastLED.show();
/*patterns if motion is detected*/
void rainbow() {
for (int i = 0; i < NUM_LEDS_1; i++) {
fill_rainbow(leds_1, i, 0, 255 / NUM_LEDS_1);
FastLED.show();
delay(50);
FastLED.clear();
The problem now: Everything works fine except the humidity_fade function, where the old_humidity value keeps changing abruptly which disturb the colour fading function that's related to humidity. I don't know where these values are coming from. If you see my code, the error is somewhere between 132-146 lines.
Could somebody please help me solve this issue?
