Arduino Code not responding to serial read
When I try to send the '@' via the serial monitor or via a c# application which has a button for it, it doesn't do anything. I am using an Arduino Due and have connected the Due to my computer via it's Native USB port and am trying to get it to exacute a while loop by using the following code. The character the program and what I am attempting to send through the serial monitor is '@'.
I have double checked that I am using the same baud and the right port and stuff also.
My code:
int go = 0;
char incomingByte;
char ch;
if(Serial.available())
ch = Serial.read();
if(ch=='@')
go = 1;
go = 0;
while (go == 1) {
// blah //blah //blah
Thanks for the help!
Disclaimer: no experience with Due.
Can you please post a complete program that exhibits the behaviour; for all I know your code snippet resides in setup() and hence chances are slim it will see a character on the serial port when your application starts.
Also please use code tags; edit your post and
Type
** **[code]** **
before your code
Type
** **[/code]** **
after your code
Next, serial monitor requires you to click the send button; this might be something you don't do. Without saying you're a beginner, it is often a beginners mistake thinking that typing something win serial monitor will result in the character being send.
Lastly, have you tried echoing received characters to the serial monitor?
sterretje:
Type
** **[code]** **
before your code
Type
** **[/code]** **
after your code
Yeah sorry I can do that, I will send it in a few hours, My computer has been shut down its 2 am.
Serial is the programming port on Due. The native USB port is SerialUSB.
sterretje:
Type
** **[code]** **
before your code
Type
** **[/code]** **
after your code
Next, serial monitor requires you to click the send button; this might be something you don’t do. Without saying you’re a beginner, it is often a beginners mistake thinking that typing something win serial monitor will result in the character being send.
Okay sorry for that delay. I have sent the ‘@’ in the serial monitor right after restarting it and the code works for about 3 seconds then stops until I unplug my Arduino and restart Arduino IDE. My code is suspose to send mouse clicks when the character @ is send and stop while # is sent, I want it to be working more than a few seconds lol.
 #include <HID.h>
#include <Mouse.h>
unsigned long seed=0, count=31;
while (--count)
  seed = (seed<<1) | (analogRead(0)&1);
randomSeed(analogRead(0));
Mouse.begin();
SerialUSB.begin(9600);
while (!SerialUSB.available());
delay(2000);
  int go = 0;
char incomingByte;
char ch;
if(SerialUSB.available())
   ch = SerialUSB.read();
  if(ch=='@')
go = 1;
   go = 0;
  while (go == 1) {
  // send data only when you receive data:
  if(ch=='@')
 go = 1;
 go = 0;
Mouse.press();
delay(75);
Mouse.release();
oqibidipo:
Yeah I already tried switching it, no changes.
while (--count)
What is the point to computing seed?
So, why do both blocks of code deal with ‘@’, and set go the same way?
Why did you post code that won’t even compile? Your indenting is atrocious. I tried to fix it, using Tools + Auto Format, but there are not the same number of { and } in your code.
PaulS:
while (–count)
So, why do both blocks of code deal with '@', and set go the same way?
Why did you post code that won't even compile? Your indenting is atrocious. I tried to fix it, using Tools + Auto Format, but there are not the same number of { and } in your code.
Yeah I think you are right that my code is the problem. It’s weird that it compiles though. So basically it works now but when I send ‘@’ it starts clicking and doesn’t stop, not even when I send the #
David1937:
Yeah I think you are right that my code is the problem. It's weird that it compiles though.
It would be weird if it compiled! As you posted it, it doesn't.
evanmars:
It would be weird if it compiled! As you posted it, it doesn’t.
Yeah it is compiling, well the full version of it. I didn’t want put it in because it’s quite confusing.
Here is the full code, sorry for it being confusing it’s generating random intervals.
#include <HID.h>
#include <Mouse.h>
while (--count)
Mouse.begin();
delay(2000);
  int go = 0;
char incomingByte;
char ch;
  if(ch=='@')
go = 1;
   go = 0;
  while (go == 1) {
  if(ch=='@')
 go = 1;
  else if (ch== '#')
 go = 0;
double number1 = random(1,100);
double number2;
if (number1 < 15) {
  number2 = random(1,16);
  number2 = random(17,95);
  for (int j = 0; j < number2; j++) {
  int i = 0;
int who;
int Sleep = 30;
int Delay;
int CPS = random(1, 100);
who = random(1, 20);
if (CPS >= 1 && CPS <= 30)
  Sleep = 70;
if (CPS >= 31 && CPS <= 60)
  Sleep = 80;
if (CPS >= 61 && CPS <= 74)
  Sleep = 110;
if (CPS >=75 && CPS <= 85)
  Sleep = 90;
if (CPS >= 86 && CPS <= 93)
  Sleep = 120;
if (CPS >=94 && CPS <= 100)
  Sleep = 100;
double ads = (random(1,20));
double last;
double test;
int cont = 1;
if (ads >=1 && ads <= 10)
  Sleep = Sleep - (random(1,5));
if (ads >=11 && ads <= 20)
  Sleep = Sleep + (random(1,5));
do {
  test = (random(30,70));
if(abs(last-test) < 10) {
   cont = 0;
if(abs(last-test) > 10) {
   cont = 1;
} while (cont == 0);
 double testv = (Sleep - test);
  Mouse.press();
  delay(test);
  Mouse.release();
  delay(testv);
 last = test;
delay(random(133,280));
  while (go == 1) {
  if(ch=='@')
 go = 1;
Once go is set to 1, what is the purpose of dealing with another ‘@’ and setting go to 1 again?
Why are you using an int, when a boolean, and true or false, is a lot more intuitive?
if (number1 < 15) {
So, you want number2 to contain 1 to 15 or 17 to 94. What a strange set of values…
(What’s) (up) (with) (the) (useless) (parentheses) (?)
random() doesn’t return a double…
Using Tools + Auto Format before posting code would certainly be a good idea. So would adding comments to explain the bizarre code.
Some SerialUSB.print() statements might just go a long ways towards explaining the mystery.
What is sending the serial data?
