Arduino code not sending all data to Max/MSP
Hi All,
I'm quite stuck with my code at the moment and am hoping someone can point me in the right direction?
The code below is taking I2C data from an MPR121 touch sensor chip (with 12 sensors attached) through a Mega. The serial data is then supposed to be transferred into Max/MSP.
Currently, Max is acknowledging when a sensor is being touched, however, it's not acknowledging which sensor is being touched, and this, is very necessary. I'm struggling because the Arduino serial monitor, which you can see attached, is correctly showing which pins/sensors have been activated. Max's monitor on the other hand, also attached, is conveniently only showing zeroes.
This leads me to believe the Arduino code is not instructing Max correctly. I've been doing standalone projects in Arduino and Max for two years now... never before have I worked with serial communication flow, so alas, I need your expertise.
Thanks for taking the time,
J.
 *  @filename   capactivite_prox_sensor_mpr121.ino
 *  @author     Julio Terra
 *  @date       May 22, 2013
 *  @version    1.0.1
 *  Please check-out the read-me for details about how to hook-up the Arduino and the MPR121
 *  breakout boards.
#include "mpr121.h"
#include <Wire.h>
#define SENSORS       13
#define TOU_THRESH    0x1F
#define REL_THRESH    0x1A
#define PROX_THRESH   0x3f
#define PREL_THRESH   0x3c
// variables: capacitive sensing
bool touchStates[SENSORS];    // holds the current touch/prox state of all sensors
bool activeSensors[SENSORS] = {1,1,1,1,1,1,1,1,1,1,1,1,1}; // holds which sensors are active (0=inactive, 1=active)
bool newData = false;         // flag that is set to true when new data is available from capacitive sensor
int irqpin = 2;               // pin that connects to notifies when data is available from capacitive sensor
void setup(){
  // attach interrupt to pin - interrupt 1 is on pin 2 of the arduino (confusing I know)
  attachInterrupt(0, dataAvailable, FALLING);
  // set-up the Serial and I2C/Wire connections
  Wire.begin();
  // set the registers on the capacitive sensing IC
  setupCapacitiveRegisters();
void loop(){
  readCapacitiveSensor();
 * dataAvailable Callback method that runs whenever new data becomes available on from the capacitive sensor.
 *   This method was attached to the interrupt on pin 2, and is called whenever that pins goes low.
void dataAvailable() {
  newData = true;
 * readCapacitiveSensor Reads the capacitive sensor values from the MP121 IC. It makes a request to
 *   the sensor chip via the I2C/Wire connection, and then parses the sensor values which are stored on
 *   the first 13 bits of the 16-bit response msg.
void readCapacitiveSensor(){
  if(newData){
    //read the touch state from the MPR121
    Wire.requestFrom(0x5A,2);
    byte tLSB = Wire.read();
    byte tMSB = Wire.read();
    uint16_t touched = ((tMSB << 8) | tLSB); //16bits that make up the touch states
    for (int i = 0; i < SENSORS; i++){  // Check what electrodes were pressed
      if (activeSensors[i] == 0) continue;
      char sensor_id [] = {'\0','\0','\0'};
      switch (i) {
        case 12:
          sensor_id[0] = 'P';
        default:
          if (i < 10) {
            sensor_id[0] = char( i+48 );
          else if (i < 12) {
            sensor_id[0] = char('1');
            sensor_id[1] = char( ( i % 10 ) + 48 );
      if (sensor_id != '\0') {
        // read the humidity level
        // if current sensor was touched (check appropriate bit on touched var)
        if(touched & (1<<i)){
          // if current pin was not previously touched send a serial message
          if(touchStates[i] == 0){
            Serial.print(sensor_id);
            Serial.print(":");
            Serial.println("touched");
          touchStates[i] = 1;
          // if current pin was just touched send serial message
          if(touchStates[i] == 1){
            Serial.print(":");
            Serial.println("not touched");
          touchStates[i] = 0;
    newData = false;
 * setupCapacitiveRegisters Updates all of configurations on the MP121 capacitive sensing IC. This includes
 *   setting levels for all filters, touch and proximity sensing activation and release thresholds, debounce,
 *   and auto-configurations options. At the end it activates all of the electrodes.
void setupCapacitiveRegisters(){
  set_register(0x5A, ELE_CFG, 0x00);
  // Section A - filtering when data is > baseline.
    // touch sensing
    set_register(0x5A, MHD_R, 0x01);
    set_register(0x5A, NHD_R, 0x01);
    set_register(0x5A, NCL_R, 0x00);
    set_register(0x5A, FDL_R, 0x00);
    // prox sensing
    set_register(0x5A, PROX_MHDR, 0xFF);
    set_register(0x5A, PROX_NHDAR, 0xFF);
    set_register(0x5A, PROX_NCLR, 0x00);
    set_register(0x5A, PROX_FDLR, 0x00);
  // Section B - filtering when data is < baseline.
    // touch sensing
    set_register(0x5A, MHD_F, 0x01);
    set_register(0x5A, NHD_F, 0x01);
    set_register(0x5A, NCL_F, 0xFF);
    set_register(0x5A, FDL_F, 0x02);
    // prox sensing
    set_register(0x5A, PROX_MHDF, 0x01);
    set_register(0x5A, PROX_NHDAF, 0x01);
    set_register(0x5A, PROX_NCLF, 0xFF);
    set_register(0x5A, PROX_NDLF, 0xFF);
  // Section C - Sets touch and release thresholds for each electrode
    set_register(0x5A, ELE0_T, TOU_THRESH);
    set_register(0x5A, ELE0_R, REL_THRESH);
    set_register(0x5A, ELE1_T, TOU_THRESH);
    set_register(0x5A, ELE1_R, REL_THRESH);
    set_register(0x5A, ELE2_T, TOU_THRESH);
    set_register(0x5A, ELE2_R, REL_THRESH);
    set_register(0x5A, ELE3_T, TOU_THRESH);
    set_register(0x5A, ELE3_R, REL_THRESH);
    set_register(0x5A, ELE4_T, TOU_THRESH);
    set_register(0x5A, ELE4_R, REL_THRESH);
    set_register(0x5A, ELE5_T, TOU_THRESH);
    set_register(0x5A, ELE5_R, REL_THRESH);
    set_register(0x5A, ELE6_T, TOU_THRESH);
    set_register(0x5A, ELE6_R, REL_THRESH);
    set_register(0x5A, ELE7_T, TOU_THRESH);
    set_register(0x5A, ELE7_R, REL_THRESH);
    set_register(0x5A, ELE8_T, TOU_THRESH);
    set_register(0x5A, ELE8_R, REL_THRESH);
    set_register(0x5A, ELE9_T, TOU_THRESH);
    set_register(0x5A, ELE9_R, REL_THRESH);
    set_register(0x5A, ELE10_T, TOU_THRESH);
    set_register(0x5A, ELE10_R, REL_THRESH);
    set_register(0x5A, ELE11_T, TOU_THRESH);
    set_register(0x5A, ELE11_R, REL_THRESH);
  // Section D - Set the touch filter Configuration
    set_register(0x5A, FIL_CFG, 0x04);
  // Section E - Set proximity sensing threshold and release
    set_register(0x5A, PRO_T, PROX_THRESH);   // sets the proximity sensor threshold
    set_register(0x5A, PRO_R, PREL_THRESH);   // sets the proximity sensor release
  // Section F - Set proximity sensor debounce
    set_register(0x59, PROX_DEB, 0x50);  // PROX debounce
  // Section G - Set Auto Config and Auto Reconfig for prox sensing
    set_register(0x5A, ATO_CFGU, 0xC9);  // USL = (Vdd-0.7)/vdd*256 = 0xC9 @3.3V
    set_register(0x5A, ATO_CFGL, 0x82);  // LSL = 0.65*USL = 0x82 @3.3V
    set_register(0x5A, ATO_CFGT, 0xB5);  // Target = 0.9*USL = 0xB5 @3.3V
    set_register(0x5A, ATO_CFG0, 0x0B);
  // Section H - Start listening to all electrodes and the proximity sensor
    set_register(0x5A, ELE_CFG, 0x3C);
 * set_register Sets a register on a device connected via I2C. It accepts the device's address,
 *   register location, and the register value.
 * @param address The address of the I2C device
 * @param r       The register's address on the I2C device
 * @param v       The new value for the register
void set_register(int address, unsigned char r, unsigned char v){
  Wire.beginTransmission(address);
  Wire.write(r);
  Wire.write(v);
  Wire.endTransmission();
