Arduino Code says undefined reference to setup and loop
I've been working on some coding for a science project and I've been having some trouble, there is an error code that I don't quite understand the error codes that are occuring, I don't know much about coding so if you could explain in the simplest way, thank you (i attached my code)
This is the error message
Build options changed, rebuilding all
core.a(main.cpp.o): In function main': /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/main.cpp:40: undefined reference to setup'
/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/main.cpp:43: undefined reference to `loop'
collect2: error: ld returned 1 exit status
Error compiling.
Rube.ino (1.65 KB)
Your arduino code needs the functions setup() and loop(). Both are missing in your code.
You probably want to add something like
  setupBlink();
  setupFade();
  loopBlink();
  loopFade();
