Arduino code to control 2 servos not giving desired output
Hello Everyone,
I am new to arduino coding and I am trying to detect an object based on its color using python script and arduino script. I am using python 3.7 and arduino uno board. My problem is whenever the object appears infront of the camera the servos start to misbehave and start moving in random direction. please help me out here:
Python script:
import serial
import time
import cv2
import numpy as np
color = input("Input Color: yellow, blue, red, green: ")
# cap = cv2.VideoCapture(0)
ser = serial.Serial("COM4", 9600, timeout=2)                    #data transfer to ardiuno through port
# ser.open()
posX = 90
posY = 90
while True:
    _, frame = cap.read()
    frame = cv2.flip(frame, 1)
    hsv_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
    #color range
    if color == 'red':
        low = np.array([161,155,84])
        high = np.array([179,255,255])
    #low_red = np.array([161,155,84])
    #high_red = np.array([179,255,255])
    elif color == 'blue':
        low = np.array([38, 86, 0])
        high = np.array([121, 255, 255])
    elif color == 'yellow':
        low = np.array([0, 116, 125])
        high = np.array([225, 255, 255])
    elif color == 'green':
        low = np.array([44,32,0])
        high = np.array([107, 185, 246])
    red_mask = cv2.inRange(hsv_frame, low, high)
    contours, _ = cv2.findContours(red_mask, cv2.RETR_TREE, cv2.CHAIN_APPROX_SIMPLE)
    contours = sorted(contours, key = lambda x: cv2.contourArea(x), reverse = True)
    rows, cols, _ = frame.shape
    print(rows, cols)
    x_center = int(rows/2)
    y_center = int(cols/2)
    for cnt in contours:
        (x, y, w, h) = cv2.boundingRect(cnt)
        cv2.rectangle(frame, (x,y), (x+w,y+h), (0,255,0), 2)
        x_medium = int((x + x + w)/2)
        y_medium = int((y + y + h)/2)
        cv2.line(frame, (x_medium, 0), (x_medium, 480), (0,255,0), 2)
        cv2.line(frame, (0, y_medium), (cols ,y_medium), (0,255,0), 2)
        center = (x_medium, y_medium)
        print("center: ", center)
#######################data to be transfered to ardiuno
        data = "X{0:.0f}Y{1:.0f}Z".format(x_medium, y_medium)
        print("output: ", data)
        # ser.write(data)
        ser.write((str(data)).encode('utf-8'))
        break
    print("for loop out")
    cv2.imshow("Main Frame", frame)
    #cv2.imshow("Main Frame", hsv_frame)
    key = cv2.waitKey(1)
    if key == ord('s'):
        break
cap.release()
cv2.destroyAllWindows()
Arduino script:
#include <Servo.h>
Servo servoVer; //Vertical Servo
Servo servoHor; //Horizontal Servo
int x;
int y;
int prevX;
int prevY;
int pos = 0;
  servoVer.attach(5); //Attach Vertical Servo to Pin 5
  servoHor.attach(6); //Attach Horizontal Servo to Pin 6
  servoVer.write(90);
  servoHor.write(90);
void Pos()
  if (prevX != x || prevY != y)
    int servoX = map(x, 480, 0, 0, 180);
    int servoY = map(y, 640, 0, 180, 0);
    servoX = min(servoX, 180);
    servoX = max(servoX, 0);
    servoY = min(servoY, 180);
    servoY = max(servoY, 0);
    prevX = servoX;
    prevY = servoY;
    servoHor.write(servoX);
    servoVer.write(servoY);
void something(){
   for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
    servoHor.write(pos);              // tell servo to go to position in variable 'pos'
    delay(5);                       // waits 15ms for the servo to reach the position
void track(){
    if(Serial.available() > 0)
      if (Serial.read() == 'X')
        x = Serial.parseInt();
        if (Serial.read() == 'Y')
          y = Serial.parseInt();
          Pos();
      while (Serial.available() > 0)
        Serial.read();
  if ( ! Serial.available() )
    something();
    track();
You should not have a big delay() in code that is receiving serial data.
Your Arduino program should be listening for data all the time and should signal to the rest of your program when a new message has been received so it can act on it.
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
Also have a look at this Simple Python - Arduino demo
The Python code should work on Windows if you edit it to use the Windows style of COM ports.
...R
