Arduino code to serial print the 10th number stored in a array of 100 number.
hi,
I'm totally new to this so can anybody help me in creating a code to serial print the 10th number stored in a array of 100 numbers. The numbers can be anything received from the tx pin from arduino.
Thanks in advance
The modulo operator (%) is what you need
Take ideas from this
//original array
//byte anArray[] = {11, 22, 33, 44, 55, 66, 77, 88, 99, 0, 123, 234, 345, 456, 789, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0};
//array amended following comments about the values used
int anArray[] = {11, 22, 33, 44, 55, 66, 77, 88, 99, 0, 123, 234, 345, 456, 789, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0};
byte numberOfElements = sizeof(anArray);
  Serial.println(numberOfElements);
  for (int x = 0 ; x < numberOfElements; x++)
    if ((x % 5) == 0)
      Serial.print(x);
      Serial.print(" : ");
      Serial.println(anArray[x]);
Bob:
Your byte array has values greater than 255, which I don't think will work. Also, to see each 10th element of the array, shouldn't the test be:
if ((x % 10 == 0 && x != 0) {
9%10 == 0 ?
If you just want to print an element of your array. This would work. Arrays start at zero so that is why one is subtracted from arrayElement
int arrayElement=9;
Serial.println(yourArrayName[arrayElement-1];
Or you could, of course, simply do
for (int x = 0; x < arraySize; x += 10)
Actually, looking closer at the thread title it seems that the OP may only want to print one element anyway !
UKHeliBob:
Wouldn't that print the 1st, 11th, 21st,...91st elements?
evanmars:
Yes, but as I said in reply #5 I only just realised that the OP seems only to want to print one element anyway.
Sorry to have caused confusion but I am not having the best of days !
venkatesh223:
int Array[100];
Serial.print(Array[9]);  // Indexes start at 0 so index 9 is the 10th number.
