They aren't errors. They are warnings. I suspect you have compiler warnings turned down or off.
Go to the "Preferences..." page and set "Compiler warnings:" to "All". When you compile again you will get helpful warnings that point out where you are doing something that doesn't look quite right to the compiler. Warnings point to code the is not a syntax error (so it WILL compile), but it is fairly likely that it is not doing what you think it is doing.
I don't need a compiler to see all the warnings, a ton of "label not used"
Somewhere\DamnedIRemote.ino: In function 'void loop()':
Somewhere\DamnedIRemote.ino:88:24: warning: statement has no effect [-Wunused-value]
case1: 0xBA45FF00;//motor1 power on/off speed=0 ("one_btn")
Somewhere\DamnedIRemote.ino:94:24: warning: statement has no effect [-Wunused-value]
case2: 0xE718FF00;//motor1 speed up (up_btn)
Somewhere\DamnedIRemote.ino:101:24: warning: statement has no effect [-Wunused-value]
case3: 0xAD52FF00;// motor1 speed down (down_btn)
Somewhere\DamnedIRemote.ino:108:24: warning: statement has no effect [-Wunused-value]
case4: 0xBB44FF00;//motor2 power on speed 0 "four_btn"
Somewhere\DamnedIRemote.ino:114:24: warning: statement has no effect [-Wunused-value]
case5: 0xA55AFF00;//motor2 speed up (FORWARD_btn)
Somewhere\DamnedIRemote.ino:121:24: warning: statement has no effect [-Wunused-value]
case6: 0xF708FF00;// motor2 speed down (REWIND_btn)
Somewhere\DamnedIRemote.ino:88:7: warning: label 'case1' defined but not used [-Wunused-label]
Somewhere\DamnedIRemote.ino:94:7: warning: label 'case2' defined but not used [-Wunused-label]
Somewhere\DamnedIRemote.ino:101:7: warning: label 'case3' defined but not used [-Wunused-label]
Somewhere\DamnedIRemote.ino:108:7: warning: label 'case4' defined but not used [-Wunused-label]
Somewhere\DamnedIRemote.ino:114:7: warning: label 'case5' defined but not used [-Wunused-label]
Somewhere\DamnedIRemote.ino:121:7: warning: label 'case6' defined but not used [-Wunused-label]
You seem to have no clue how a proper switch case statement is structured.
Look that up again.
