Arduino code works with Uno, but not with NodeMCU
On Uno, I input two values in the serial monitor and the output is printed. On NodeMCU, the monitor doesn't show anything, even if I want to print a line before the inputs.
Does anybody have an idea how to make it work? Code is way too long to paste it here so I'm sending a link to the file. I think that the issue is in the header file, but I'm not sure.
fisUntitled2.ino (8.63 KB)
fis_header.h (651 Bytes)
Can you attach the code to a post?
I don't want to sign-up to another hosting site.
Sorry, I've edited it now. I got an error when I tried to upload it before, but I now realized .rar isn't supported.
But INO is
I'm not downloading a ZIP file
// Matlab .fis to arduino C converter v2.0.1.25122016
// - Karthik Nadig, USA
// Please report bugs to:
// https://github.com/karthiknadig/ArduinoFIS/issues
// If you don't have a GitHub account mail to karthiknadig@gmail.com
#include "fis_header.h"
String A, B;
// Number of inputs to the fuzzy inference system
const int fis_gcI = 2;
// Number of outputs to the fuzzy inference system
const int fis_gcO = 1;
// Number of rules to the fuzzy inference system
const int fis_gcR = 9;
FIS_TYPE g_fisInput[fis_gcI];
FIS_TYPE g_fisOutput[fis_gcO];
// Setup routine runs once when you press reset:
  // initialize the Analog pins for input.
  // Pin mode for Input: input1
  pinMode(0 , INPUT);
  // Pin mode for Input: input2
  pinMode(1 , INPUT);
  // initialize the Analog pins for output.
  // Pin mode for Output: output
  pinMode(2 , OUTPUT);
// Loop routine runs over and over again forever:
  if (Serial.available()) {
    String justRates = Serial.readStringUntil('\n');
    int aSpaceIndex = justRates.indexOf(",");
    int bSpaceIndex = justRates.indexOf(",", aSpaceIndex + 1);
    A = (justRates.substring(0, aSpaceIndex));
    B = (justRates.substring(aSpaceIndex + 1, bSpaceIndex));
    int x = A.toInt();
    int y = B.toInt();
    Serial.println("A : " + String(A) + " B : " + String(B));
    // Read Input: input1
    g_fisInput[0] = x;
    // Read Input: input2
    g_fisInput[1] = y;
    g_fisOutput[0] = 0;
    fis_evaluate();
    // Set output vlaue: output
    analogWrite(2 , g_fisOutput[0]);
    Serial.println(g_fisOutput[0]);
// Support functions for Fuzzy Inference System
// Gaussian Member Function
FIS_TYPE fis_gaussmf(FIS_TYPE x, FIS_TYPE* p)
  FIS_TYPE s = p[0], c = p[1];
  FIS_TYPE t = (x - c) / s;
  return exp(-(t * t) / 2);
FIS_TYPE fis_prod(FIS_TYPE a, FIS_TYPE b)
  return (a * b);
FIS_TYPE fis_probor(FIS_TYPE a, FIS_TYPE b)
  return (a + b - (a * b));
FIS_TYPE fis_sum(FIS_TYPE a, FIS_TYPE b)
  return (a + b);
FIS_TYPE fis_array_operation(FIS_TYPE *array, int size, _FIS_ARR_OP pfnOp)
  int i;
  FIS_TYPE ret = 0;
  if (size == 0) return ret;
  if (size == 1) return array[0];
  ret = array[0];
  for (i = 1; i < size; i++)
    ret = (*pfnOp)(ret, array[i]);
  return ret;
// Data for Fuzzy Inference System
// Pointers to the implementations of member functions
_FIS_MF fis_gMF[] =
  fis_gaussmf
// Count of member function for each Input
int fis_gIMFCount[] = { 3, 3 };
// Count of member function for each Output
int fis_gOMFCount[] = { 9 };
// Coefficients for the Input Member Functions
FIS_TYPE fis_gMFI0Coeff1[] = { 2.06130253937487, 0.246877358937878 };
FIS_TYPE fis_gMFI0Coeff2[] = { 1.55130611406437, 5.64719384224608 };
FIS_TYPE fis_gMFI0Coeff3[] = { 0.756873995521849, 27.000838863279 };
FIS_TYPE* fis_gMFI0Coeff[] = { fis_gMFI0Coeff1, fis_gMFI0Coeff2, fis_gMFI0Coeff3 };
FIS_TYPE fis_gMFI1Coeff1[] = { 142.009256148267, 390.581074772965 };
FIS_TYPE fis_gMFI1Coeff2[] = { 140.906651425662, 722.503198624614 };
FIS_TYPE fis_gMFI1Coeff3[] = { 141.931284820756, 1054.44632396324 };
FIS_TYPE* fis_gMFI1Coeff[] = { fis_gMFI1Coeff1, fis_gMFI1Coeff2, fis_gMFI1Coeff3 };
FIS_TYPE** fis_gMFICoeff[] = { fis_gMFI0Coeff, fis_gMFI1Coeff };
// Coefficients for the Output Member Functions
FIS_TYPE fis_gMFO0Coeff1[] = { 0, 0, 4.18244207402222 };
FIS_TYPE fis_gMFO0Coeff2[] = { 0, 0, 1.44961297726191 };
FIS_TYPE fis_gMFO0Coeff3[] = { 0, 0, -0.368050242260879 };
FIS_TYPE fis_gMFO0Coeff4[] = { 0, 0, 4.33138615173981 };
FIS_TYPE fis_gMFO0Coeff5[] = { 0, 0, 1.5928210476751 };
FIS_TYPE fis_gMFO0Coeff6[] = { 0, 0, -0.448924883325473 };
FIS_TYPE fis_gMFO0Coeff7[] = { 0, 0, -0.00652070543486851 };
FIS_TYPE fis_gMFO0Coeff8[] = { 0, 0, -0.0137518922235143 };
FIS_TYPE fis_gMFO0Coeff9[] = { 0, 0, -0.337080359760686 };
FIS_TYPE* fis_gMFO0Coeff[] = { fis_gMFO0Coeff1, fis_gMFO0Coeff2, fis_gMFO0Coeff3, fis_gMFO0Coeff4, fis_gMFO0Coeff5, fis_gMFO0Coeff6, fis_gMFO0Coeff7, fis_gMFO0Coeff8, fis_gMFO0Coeff9 };
FIS_TYPE** fis_gMFOCoeff[] = { fis_gMFO0Coeff };
// Input membership function set
int fis_gMFI0[] = { 0, 0, 0 };
int fis_gMFI1[] = { 0, 0, 0 };
int* fis_gMFI[] = { fis_gMFI0, fis_gMFI1};
// Output membership function set
int* fis_gMFO[] = {};
// Rule Weights
FIS_TYPE fis_gRWeight[] = { 1, 1, 1, 1, 1, 1, 1, 1, 1 };
// Rule Type
int fis_gRType[] = { 1, 1, 1, 1, 1, 1, 1, 1, 1 };
// Rule Inputs
int fis_gRI0[] = { 1, 1 };
int fis_gRI1[] = { 1, 2 };
int fis_gRI2[] = { 1, 3 };
int fis_gRI3[] = { 2, 1 };
int fis_gRI4[] = { 2, 2 };
int fis_gRI5[] = { 2, 3 };
int fis_gRI6[] = { 3, 1 };
int fis_gRI7[] = { 3, 2 };
int fis_gRI8[] = { 3, 3 };
int* fis_gRI[] = { fis_gRI0, fis_gRI1, fis_gRI2, fis_gRI3, fis_gRI4, fis_gRI5, fis_gRI6, fis_gRI7, fis_gRI8 };
// Rule Outputs
int fis_gRO0[] = { 1 };
int fis_gRO1[] = { 2 };
int fis_gRO2[] = { 3 };
int fis_gRO3[] = { 4 };
int fis_gRO4[] = { 5 };
int fis_gRO5[] = { 6 };
int fis_gRO6[] = { 7 };
int fis_gRO7[] = { 8 };
int fis_gRO8[] = { 9 };
int* fis_gRO[] = { fis_gRO0, fis_gRO1, fis_gRO2, fis_gRO3, fis_gRO4, fis_gRO5, fis_gRO6, fis_gRO7, fis_gRO8 };
// Input range Min
FIS_TYPE fis_gIMin[] = { -4.4, 390 };
// Input range Max
FIS_TYPE fis_gIMax[] = { 42.1, 1055 };
// Output range Min
FIS_TYPE fis_gOMin[] = { 0 };
// Output range Max
FIS_TYPE fis_gOMax[] = { 4 };
// Data dependent support functions for Fuzzy Inference System
// None for Sugeno
// Fuzzy Inference System
void fis_evaluate()
  FIS_TYPE fuzzyInput0[] = { 0, 0, 0 };
  FIS_TYPE fuzzyInput1[] = { 0, 0, 0 };
  FIS_TYPE* fuzzyInput[fis_gcI] = { fuzzyInput0, fuzzyInput1, };
  FIS_TYPE fuzzyOutput0[] = { 0, 0, 0, 0, 0, 0, 0, 0, 0 };
  FIS_TYPE* fuzzyOutput[fis_gcO] = { fuzzyOutput0, };
  FIS_TYPE fuzzyRules[fis_gcR] = { 0 };
  FIS_TYPE fuzzyFires[fis_gcR] = { 0 };
  FIS_TYPE* fuzzyRuleSet[] = { fuzzyRules, fuzzyFires };
  FIS_TYPE sW = 0;
  // Transforming input to fuzzy Input
  int i, j, r, o;
  for (i = 0; i < fis_gcI; ++i)
    for (j = 0; j < fis_gIMFCount[i]; ++j)
      fuzzyInput[i][j] =
        (fis_gMF[fis_gMFI[i][j]])(g_fisInput[i], fis_gMFICoeff[i][j]);
  int index = 0;
  for (r = 0; r < fis_gcR; ++r)
    if (fis_gRType[r] == 1)
      fuzzyFires[r] = 1;
        index = fis_gRI[r][i];
        if (index > 0)
          fuzzyFires[r] = fis_prod(fuzzyFires[r], fuzzyInput[i][index - 1]);
        else if (index < 0)
          fuzzyFires[r] = fis_prod(fuzzyFires[r], 1 - fuzzyInput[i][-index - 1]);
          fuzzyFires[r] = fis_prod(fuzzyFires[r], 1);
      fuzzyFires[r] = 0;
        if (index > 0)
          fuzzyFires[r] = fis_probor(fuzzyFires[r], fuzzyInput[i][index - 1]);
        else if (index < 0)
          fuzzyFires[r] = fis_probor(fuzzyFires[r], 1 - fuzzyInput[i][-index - 1]);
          fuzzyFires[r] = fis_probor(fuzzyFires[r], 0);
    fuzzyFires[r] = fis_gRWeight[r] * fuzzyFires[r];
    sW += fuzzyFires[r];
  if (sW == 0)
    for (o = 0; o < fis_gcO; ++o)
      g_fisOutput[o] = ((fis_gOMax[o] + fis_gOMin[o]) / 2);
      FIS_TYPE sWI = 0.0;
      for (j = 0; j < fis_gOMFCount[o]; ++j)
        fuzzyOutput[o][j] = fis_gMFOCoeff[o][j][fis_gcI];
          fuzzyOutput[o][j] += g_fisInput[i] * fis_gMFOCoeff[o][j][i];
        index = fis_gRO[r][o] - 1;
        sWI += fuzzyFires[r] * fuzzyOutput[o][index];
      g_fisOutput[o] = sWI / sW;
​Oh, it said I exceeded 9000 characters when I tried that.
Here's the header file.
#define FIS_TYPE float
#define FIS_RESOLUSION 101
#define FIS_MIN -3.4028235E+38
#define FIS_MAX 3.4028235E+38
typedef FIS_TYPE(*_FIS_MF)(FIS_TYPE, FIS_TYPE*);
typedef FIS_TYPE(*_FIS_ARR_OP)(FIS_TYPE, FIS_TYPE);
typedef FIS_TYPE(*_FIS_ARR)(FIS_TYPE*, int, _FIS_ARR_OP);
float is float, array is array, String is String, even Serial is Serial. That's all the same.
The difference is the pin numbers.
Why do you set digital pin 0 and 1 to INPUT and then don't use them ?
Why is there confusing comment about analog inputs, there are no analog inputs used.
Can the nodeMCU do a analogWrite() to pin 2 ?
Wow, just like that, you've fixed my code. I though those lines were just laying around doing nothing, but pins defined like that confused NodeMCU as it uses differen't naming. I've deleted all of that and now it's working fine.
Thanks for your help.
