Arduino Coding
I am unable to find what's the problem in the code. I want to upload my Arduino data online. By directly operating GSM900 with Hyperterminal I was able to send the data. Code is as follows
    "method": "put",
    "resource": "/feeds/1820378806",
    "params": {},
    "headers": {"X-ApiKey":"**********"},
    "body":  {
        "version" : "1.0.0",
        "datastreams":  [
                "id": "Humidity",
                "current_value": "12"
But when I try to write it in Arduino IDE, it is not working. Please help !
{Serial.begin(9600);
upload();
void upload()
  Serial.println("AT+CGATT?");
  Serial.println("AT+CSTT=\"airtelgprs.com\"");//start task and setting the APN,
  Serial.println("AT+CIICR");//bring up wireless connection
  delay(3000);
  Serial.println("AT+CIFSR");//get local IP adress
  delay(2000);
  Serial.println("AT+CIPSPRT=0");
  delay(3000);
  Serial.println("AT+CIPSTART=\"tcp\",\"api.xively.com\",\"8081\"");//start up the connection
  delay(2000);
  Serial.println("AT+CIPSEND");//begin send data to remote server
  delay(4000);
  Serial.print("{\"method\": \"put\",\"resource\": \"/feeds/1820378806/\",\"params\"");//here is the feed you apply from pachube
  Serial.print(": {},\"headers\": {\"X-ApiKey\":\"**********"},");//in here, you should replace your pachubeapikey
  Serial.print("\"body\":");
  Serial.print(" {\"version\": \"1.0.0\",\"datastreams\": ");
  Serial.println("[{\"id\": \"Humidity\",\"current_value\": \"12\"}]}}");
  Serial.println((char)26);//sending
  delay(5000);//waitting for reply, important! the time is base on the condition of internet
  Serial.println("AT+CIPCLOSE");//close the connection
  delay(100);
What kind of device are you using the Serial port to talk to? How is that device attached to the Arduino?
If you have the option of NOT using the Serial port to talk to it, take advantage of that option.
The device sends some kind of response to the commands you send it. Ignoring them it not a good idea.
