Hello everyone, I have just finished making the physical part of a coin counter machine (very crude, out of cardboard and silicone, and yes, very ugly) but I am a little stuck on the coding part.
I am using an optocoupler from an old printer and I've gotten it to display the number in the serial terminal, and also beep when a coin is successfully "seen" and make a set of beeps when it reaches a multiple of ten.
Now I am trying to make it do 'n' sets of three beeps, to tell you the number, as it doesn't have a display, and I'm trying to use interrupts, which I am new to (I know it sounds stupid, because you will have to wait for it to stop beeping after you've pressed the button, but maybe you can help me make it only read the ones of the number, and leave the tens and/or hundreds alone).
Here is my code so far (only the interrupt part isn't working):
#define oc analogRead(A0)
int yep = 0;
volatile int number = 0;
volatile int i = 1;
#define treshold 500
int abc;
pinMode(2, INPUT);
attachInterrupt(0, beepNumber, FALLING);
if (yep == 0) {
if (oc > treshold) {
number = number + 1;
yep = 1;
Serial.println(number);
abc = number % 10;
tone(3, 6000);
delay(100);
noTone(3);
if (abc == 0) {
tone(3, 5000);
delay(50);
noTone(3);
delay(50);
tone(3, 5000);
delay(50);
noTone(3);
delay(50);
tone(3, 5000);
delay(50);
noTone(3);
delay(50);
noTone(3);
if (oc < treshold) {
yep = 0;
void beepNumber() {
for(i = 1; i<=number;i++) {
tone(3, 6000);
delay(50);
noTone(3);
Any help is much appreciated, I know there are some mistakes.
