Whenever I run this program, it says scope not defined which I really don't understand how it works
It says displayAmountSerial(); not defined in scope. I tried putting outside the bracket, but the error was still showing up.
How do I proceed forward?
// Include Libraries
#include "Arduino.h"
#include "LiquidCrystal_PCF8574.h"
// Pin Definitions
#define IROBJAVOID_1_PIN_OUT 2
#define IROBJAVOID_2_PIN_OUT 3
#define LCD_ADDRESS 0x3F
//#define LCD_ADDRESS 0x27
#define LCD_ROWS 2
#define LCD_COLUMNS 16
#define SCROLL_DELAY 150
#define BACKLIGHT 255
LiquidCrystal_PCF8574 lcdI2C;
const int timeout = 10000; //define timeout of 10 sec
char menuOption = 0;
long time0;
const int pinIr50f = 3;
const int pinIr1d = 2;
int IRvalue50f = 0;
int IRvalue1d = 0;
const int pinIrStart = 3;
int pinMotor = 4;
int IRvalueStart = 0;
int coinCount = 0;
int MoneyWorth = 0;
String MessageToPrint = "p";
void coinDetected() {
coinCount ++;
digitalWrite(pinMotor, LOW);
char menu()
Serial.println(F("\nWhich component would you like to test?"));
Serial.println(F("(1) IR Obstacle Avoidance Sensor #1"));
Serial.println(F("(2) IR Obstacle Avoidance Sensor #2"));
Serial.println(F("(3) LCD Display Screen 16x2 I2C"));
Serial.println(F("(menu) send anything else or press on board reset button\n"));
while (!Serial.available());
while (Serial.available())
char c = Serial.read();
if (isAlphaNumeric(c))
if (c == '1')
Serial.println(F("Now Testing IR Obstacle Avoidance Sensor #1"));
else if (c == '2')
Serial.println(F("Now Testing IR Obstacle Avoidance Sensor #2"));
else if (c == '3')
Serial.println(F("Now Testing LCD Display Screen 16x2 I2C"));
Serial.println(F("illegal input!"));
return 0;
time0 = millis();
return c;
pinMode(pinIr50f, INPUT);
pinMode(pinIr1d, INPUT);
while (!Serial) ;
Serial.println("start");
pinMode(IROBJAVOID_1_PIN_OUT, INPUT);
pinMode(IROBJAVOID_2_PIN_OUT, INPUT);
lcdI2C.begin(LCD_COLUMNS, LCD_ROWS, LCD_ADDRESS, BACKLIGHT);
menuOption = menu();
IRvalue50f = digitalRead(pinIr50f);
IRvalue1d = digitalRead(pinIr1d);
if (IRvalue50f == 0)
Serial.println("It was a 50f coin that was detected");
coinDetected();
MoneyWorth = MoneyWorth + 50;
displayAmount();
delay(200);
if (IRvalue1d == 0) {
Serial.println("It was a 1d coin that was detected");
coinDetected();
displayAmount();
delay(200);
if (menuOption == '1') {
bool irObjAvoid_1Var = !digitalRead(IROBJAVOID_1_PIN_OUT);
Serial.print(F("ObjAvoid: ")); Serial.println(irObjAvoid_1Var);
else if (menuOption == '2') {
bool irObjAvoid_2Var = !digitalRead(IROBJAVOID_2_PIN_OUT);
Serial.print(F("ObjAvoid: ")); Serial.println(irObjAvoid_2Var);
else if (menuOption == '3') {
lcdI2C.clear();
lcdI2C.print(" Total amount ") // Print print String to LCD on first line
lcdI2C.selectLine(2); // Set cursor at the begining of line 2
lcdI2C.print(" Rocks! "); // Print print String to LCD on second line
if (millis() - time0 > timeout)
