Arduino colour matching game programming questions
Hello! Please pardon any glaring errors made in the code that was overlooked, this is a school project and we are mere amateurs. We are making a colour matching game. This project uses 1 RGB LED and 4 buttons. Players press a start button to start the LED lighting sequence, then wait for the LED to stop at a certain colour. They them have to press a button corresponding to that button. There is also a buzzer.
The game 1. Player presses start button 2. Light and sound sequence commences 3. Random ledcolour generated,LED lights up in that colour 4.If the correct button is pressed,light and sound sequence commences. If the wrong button is pressed, another light and sound sequence commences.
We have encountered problems with coding. This is the code
//buttons
const int matchredPin= 13; //red button
const int matchgreenPin= 12; //greeen button
const int matchbluePin= 7; //blue button
const int matchyellowPin= 4; //yellow button
const int startPin= 2; //start button
//buzzer
const int pinSpeaker= 6;
//RGB
int redPin= 11;
int greenPin= 10;
int bluePin= 9;
//random ledcolour
int ledcolor = 0;
int currentState=LOW;
void setColor(int red, int green, int blue)
        analogWrite(redPin, red);
        analogWrite(greenPin, green);
        analogWrite(bluePin, blue); }
        pinMode(matchredPin, INPUT);
        pinMode(matchgreenPin, INPUT);
        pinMode(matchbluePin, INPUT);
        pinMode(startPin, INPUT);
        pinMode(matchyellowPin, INPUT);
        pinMode(redPin, OUTPUT);
        pinMode(greenPin, OUTPUT);
        pinMode(bluePin, OUTPUT); }
int ledcolor = random(4); //this randomly selects a number between 0 and 3
{  //Start button
currentState=digitalRead(startPin);//read input level from pin 2 into currentState
if(currentState == HIGH)   //when the switch is pressed, the voltage is pulled HIGH,
{      //opening colour sequence
       setColor(255, 0, 0); //red
       setColor(0, 0, 0); //no colour
       delay(700);
       setColor(0, 255, 0); //green
       delay(700);
       setColor(0, 0, 255); //blue
       delay(700);
       setColor(255, 255, 0); //yellow
       //opening buzzer sequence
       tone(pinSpeaker, 450, 1000);
       delay(700);
       tone(pinSpeaker, 300, 1000);
       delay(700);
       delay(700);
       delay(700);
       switch (ledcolor) {
case 0: //if ledcolor equals 0 then the led will turn red
case 1: //if ledcolor equals 1 then the led will turn green
case 2: //if ledcolor equals 2 then the led will turn blue
case 3: //if ledcolor equals 3 then the led will turn yellow
break; }
       setColor(0, 0, 0);}
       tone(pinSpeaker, 0, 0);
currentState = digitalRead(redPin);
if (currentState = HIGH &&  ledColor == 0)
  //same as opening colour sequence
  delay(700);
  delay(700);
  delay(700);
  //buzzer
  tone(pinSpeaker, 450, 500);
  tone(pinSpeaker, 0, 700); //no sound
  tone(pinSpeaker, 300, 500);
  tone(pinSpeaker, 0, 700);//no sound
  setColor(0, 0, 0);}
//Wrong- when red button is pressed when LED is green/blue/yellow:
if (currentState = HIGH && ledcolor == 1) //when it is green
if else (currentState = HIGH && ledcolor == 2) //when it is blue
if else (currentState = HIGH && ledcolor == 3) //when it is yellow
{ //led
  setColor(255, 0, 0); //lights up red
  setColor(0, 0, 0); //no light
  delay(250);
  delay(250);
  delay(250);
  //buzzer
  tone(pinSpeaker, 550, 2250); //BUZZZzzzzz...
  setColor(0, 0, 0);}
//green button
currentState = digitalRead(greenPin);
  delay(700);
  delay(700);
  delay(700);
  //buzzer
  setColor(0, 0, 0);}
//Wrong- when green button is pressed when LED is red/blue/yellow
if (currentState = HIGH && ledcolor == 0) //when it is red
{ //led
  setColor(0, 255, 0); //lights up green
  delay(250);
  delay(250);
  delay(250);
  //buzzer
  setColor(0, 0, 0);}
//blue button
currentState = digitalRead(bluePin);
if (currentState = HIGH && ledcolor == 2)
  delay(700);
  delay(700);
  delay(700);
  //buzzer
  setColor(0, 0, 0);}
//Wrong- when blue button is pressed when LED is green/red/yellow:
if else (currentState = HIGH && ledcolor == 0) //when it is red
{ //led
  setColor(0, 0, 255); //lights up blue
  //buzzer
  setColor(0, 0, 0);}
Here are some urgent questions we have: 1. To determine the random led colour we used a switch case. Is this incorrect? If so, is there any other code we can use instead? It would be extremely kind of you to provide examples. :) 2. At the start of the code for each button, we wrote currentState = the pin. Is this incorrect? 3. Error messages that need to be resloved:
 error: expected initializer before 'int'
         error: expected unqualified-id before '{' token
          Error compiling.
We do know that this resembles a bunch of code plucked from various other projects, modified and thrown together into a huge mess, because it is. However, any help is greatly appreciated. If you spot any mistakes, please inform us.
You forgot something - here, { have one of mine.
Oops
Thanks @ AWOL.
