Every now and then the com port the arduino is connected to fails and I need to unplug it and plug it in again. I am running XP and on the Device Managaer the Arduino is always there and working fine but the Arduino window says its not there and under tools -> Serial Ports, its also not there. I changed computers incase the USB ports were fried and I get the same problem. I am using a lot of Serial communication so i wonder if that somehow does something. Any help would be great.
Thanks,
Andy
What do you have connected to your board?
I have a DTMF serial decoder hooked up to it. So its receiving bytes via the Rx and then sending them back to the computer serial window.
Andy
OK. Are you here to get help or did you just need to vent?
LOL
BTW If its connected to pins 1 & 2, it cant interfere with serial communication.
Um not really sure what the comment means. I have seen this problem posted before but I have never seen anyone come with an answer. I dont think its something that has anything to do with my current project though. I try to avoid using the rx tx perhaps. It probably fails once every 10 updates,
Andy
andycomic:
In order to offer helpful suggestions, we need meaningful details. "I have a DTMF serial decoder" is slightly meaningful but does not include any details. "I have something connected to my board" provides about the same meaning and detail.
oh my bad, actually i should not have mentioned that anyway. its fails in all situations. Even when just uploading the simple blink example on both of my computers. Its not a crippling problem but its kinda annoying. Sometimes I get the error 'comm port already in use', other times it just cant find it.
Thanks,
Andy
With what connected to the board?
