Arduino command line "fatal error: Scanner_uC.h: No such file or directory"
I am trying to use command line as described in Arduino/manpage.adoc at master · arduino/Arduino · GitHub
$  arduino --upload keybrd_3a_multi-layerHold.ino
Picked up JAVA_TOOL_OPTIONS:
Loading configuration...
Initializing packages...
Preparing boards...
Verifying and uploading...
In file included from keybrd_3a_multi-layerHold.ino:4:0:
instantiations_scanners1.h:1:24: fatal error: Scanner_uC.h: No such file or directory
 #include <Scanner_uC.h>
compilation terminated.
Error compiling.
Scanner_uC.h is in a sketchbook library.
It compiles from the Arduino IDE.
Why can the command line not find Scanner_uC.h?
I am using Teensy LC and Linux.
Thank you.
Do you have the default "sketchbook.path" set correctly? You can check the default value with:
arduino --get_pref sketchbook.path
It needs that path to find the 'libraries' directory.
Hi johnwasser, thanks for taking a look.
From the terminal: arduino --get_pref sketchbook.path gets popup error message "unknown option: --get_pref".
From Arduino IDE > File > Preferences > Sketchbook location: /home/wolfv/Documents/Arduino
Scanner_uC.h is located in: /home/wolfv/Documents/Arduino/keybrd_proj/keybrd/src/Scanner_uC.h Which is symlinked from /home/wolfv/Documents/Arduino/libraries The sym link is good because Scanner_uC.h compiles on Arduino IDE. This is on Linux.
It should be --get-pref
The default “sketchbook.path” set correctly:
$ arduino --get-pref sketchbook.path
Preparing boards...
The IDE must be adding some magic to put the home/wolfv/Documents/Arduino/keybrd_proj/keybrd/src/ directory in the include file search path.
johnwasser: The IDE must be adding some magic to put the home/wolfv/Documents/Arduino/keybrd_proj/keybrd/src/ directory in the include file search path.
Not sure what you mean. The only magic is that /home/wolfv/Documents/Arduino/keybrd_proj/keybrd/src/Scanner_uC.h is symlinked from /home/wolfv/Documents/Arduino/libraries.
