arduino communicate with C++ (code blocks)
I have an Arduino and I would like to communicate with my computer. I would like to use usb (COM3) ( I think it is the easiest way). I use C++ ( Code Blocks) on my computer. I wan't to send an variable from computer to my arduino.
I've written the Arduino code:
// receiver int data;
void setup() { Serial.begin(9600); pinMode (13, OUTPUT); }
void loop() { if (Serial.available()) { data = Serial.read(); if (data==1){ digitalWrite(13, HIGH); delay(100); } } digitalWrite(13, LOW); }
I want to write the sender code in C++ ( Code Blocks) which send an variable (data=1) .
Can you help me?
I think you need to import the serial library. Read here: it could help you.. http://stackoverflow.com/questions/11677639/two-way-c-communication-over-serial-connection
