I have an underground Copper cable which is transmitting 12V , I want to use this cable for displaying temperature in a place which is as far as 5 kms , to my office , and I can't use any wireless protocol.
The 12V cable is already installed so I want to use this for communication. Can I use relays to convert 12V to 5V(1s) and 0s?
Have you thought about LO-RA wireless which has a much greater range ?
Think you may have some issues with that distance using wire unless it is screened and twisted to prevent loops and other signal issues.
Then what you ask is impossible because the telephone uses DC on the wires to indicate to the central office when the hand set goes "off hook". When you pick up the hand set a switch is closed completing the circuit and indicating the telephone is in use.
If these 'wires' are used for a utility company provided telephone connection, in a lot of places in the World, you need regulatory approval to connect to the wires ..............
