I'd like to connect arduino with a solar converter. The solar converter is of the following type:
I found no manual for it. The plate is marked CPK2420-V2.5.
According to available documentation, the solar converter should read RS485. However, it does not work, I tried it several times according to available information for similar projects.
//Rs485
//Arduino modbus master
//Knihovny
#include <ModbusMaster.h> //Library for using ModbusMaster
#define MAX485_DE 3
#define MAX485_RE_NEG 2
ModbusMaster node; //object node for class ModbusMaster
int pocet = 59; // pocet registru k vycteni
int8_t j, result;
int16_t data[59];
void preTransmission() { //Function for setting stste of Pins DE & RE of RS-485
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission() {
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
Serial.println("CIRCUIT DIGEST");
Serial.println("Arduino");
Serial.println("Modbus Master");
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
Serial.begin(115200); //Baud Rate as 115200
node.begin(1, Serial); //Slave ID as 1
node.preTransmission(preTransmission); //Callback for configuring RS-485 Transreceiver correctly
node.postTransmission(postTransmission);
Serial.println("Start");
void loop(){
uint8_t j, result;
int16_t data[pocet];
//result = node.readHoldingRegisters(0, pocet);
Serial.print("Co tam mam?");
if (result == node.ku8MBSuccess)
Serial.println("1_??");
result = node.readInputRegisters(0x3100, 10);
Serial.println("2_??");
result = node.readInputRegisters(0x311A, 2);
Serial.println("3_??");
result = node.readHoldingRegisters(0x9000, 14);
Serial.println("4_??");
delay(2000); //delay 2s
After several attempts, I found that I could read the serial line (only Rx, Tx).
//Serial
int16_t incomingByte = 0; // for incoming serial data
int c = 0;
//Serial.println("data");
if (Serial.available())
c++;
//Serial.println("neco");
incomingByte = Serial.read();
// say what you got:
//Serial.print("I received: ");
//Serial.println(incomingByte, DEC);
Serial.println(incomingByte);
if(c>=46){
c = 0;
}else{
//c = 0;
//delay(1000);
After reading, I get this data ... The number of data is not always the same so I don't know how to sort them to match the real state.
//Data
08:27:53.581 -> Start
08:27:53.581 -> 3
08:27:53.581 -> 1
08:27:53.581 -> 0
08:27:53.581 -> 3
08:27:53.581 -> 43
08:27:53.615 -> 26
08:27:53.615 -> 2
08:27:53.615 -> 23
08:27:53.615 -> 64
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 3
08:27:53.615 -> 0
08:27:53.615 -> 244
08:27:53.615 -> 0
08:27:53.615 -> 10
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 181
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 40
08:27:53.615 -> 0
08:27:53.615 -> 0
08:27:53.615 -> 2
08:27:53.615 -> 43
08:27:53.615 -> 26
08:27:53.615 -> 3
08:27:53.615 -> 1
08:27:53.615 -> 0
08:27:53.615 -> 3
08:27:53.615 -> 43
08:27:53.681 -> 26
08:27:53.681 -> 3
08:27:53.681 -> 1
08:27:53.681 -> 0
08:27:53.681 -> 3
08:27:53.681 -> 43
08:27:53.748 -> 26
I would like to ask if anyone has encountered a similar problem? Does anyone know how to solve this problem?
Thank you in advance for your reply
Regards
Hynek
