(Arduino Compatible) Microcontroller with multuple A/D converters
EDIT: The Maple Leaf has two ADCs which can be simultaniously used. As far as I can tell this is the closest thing to an Arduino board with multiple ADCs.
OLD MESSAGE:
Hi Everyone
Can anyone recomend a arduino-clone or other microcontroller which has several A/D converters? I have seen that some of the netduinos have multiple AD converters, but I would love to use a board which I can program using the regular Arduino Language.
Any recomandations?
Thanks
P.
edit: the netduinos have a "One 8-channel 10-bit Analog-to-Digital Converter, Four Channels Multiplexed with Digital I/Os" I misinterpreted that. It actually simply multiplexes one a/d converter as well... Smart | Connected | Secure | Microchip Technology
edit2: The chip used in the Maple by LeafLab (STM32 F103RB) has 2 Analog to Digital Converters. I am not sure if both are brought out to the board though.
Have you considered using an external SPI or I2C converter? I believe that’s what most Arduino folks do to add additional converters.
yes. I will probably either use several of these:
or this here:
http://www.analog.com/static/imported-files/data_sheets/AD7656_7657_7658.pdf
as suggested in this thread here:Arduino Forum
I was hover wondering, if I could save myself some extra work by simply using a different board. But I have been reading up on data-sheets and I guess that is unlikely...
edit: @coding badly. Is there any external converter you can recommend? I need at least 4 channels
Could I use this as an A/D converter?
fkeel:
Unfortunately, my only experience is vicarious. I can say that the forum discussions about external converters seem to be primarily positive (easy to get working; good results) but that does not help you very much.
I vaguely recall that CrossRoads has posted links to Analog Devices training sessions. I believe Anachrocomputer has posted often about digital-to-analog conversion (wrong direction but he seems to have an interest in the general topic). You may have luck focusing a search on those two.
Oh wait...
as suggested in this thread here: Arduino Forum
...looks like you already have the attention of CrossRoads. Never mind.
Wow. There's a big difference between those two.
Enough of the sidebar. The best I can do is recommend processors to avoid...
ATtiny2313 - no analog-to-digital converter
ATtiny84 - one
ATtiny85 - one
ATmega328 - one
Unfortunately, the parametric search does not include converter count...
Here is an external pretty nice I2C 16 bit A/D converter, it’s based on the TI ADS1115 chip. It can be run as either two differential channels or four single ended analog input. Can be run at 5vdc and is breadboard friendly. So far my check out of the device is very favorable, I can detect a 1 microvolt change at the highest gain setting of +/- .256 vdc full range, but can still read 0-5vdc at it’s lowest gain setting, but still getting .000187 volts per step resolution. Seems very stable and the large number of programmable range options can save needing to use external op-amps for interfacing things like strain gages and other Wheatstone bridge type sensors.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230619695873&ssPageName=STRK:MEWAX:IT
Datasheet: http://www.ti.com/lit/ds/sbas444b/sbas444b.pdf
Here is a sketch I wrote this weekend to check out the device:
/* Basic testing and check out sketch for a TI ADS1115 4 channel,16 bit, I2C, analog to digital converter chip
   Leftyretro 08/06/11
#include <Wire.h>
int topofScale;   // made global to use adc range value to display millivolt reading conversion
    Wire.begin();  // join I2C bus
    Serial.begin(38400); // initialize serial communication
    setConfiguration();  // configure ADS1115 chip for range and channel desired
    int   rawValue; // holds 16 bit result read from A/D device
    int scaledValue; // to convert to millivolts
    byte userKeys;
    Serial.print("Analog input #1 counts =  ");
    rawValue = getadcReading();  // read current A/D value
    Serial.print(rawValue);
    Serial.print("  Millvolts =  ");
    scaledValue = map(rawValue, 0, 32767, 0, topofScale);
    Serial.print(scaledValue);
    Serial.println("     Hit any key to continue");
    while(Serial.available() < 1) {}   // wait for user keystroke
    while(Serial.available() > 0) {userKeys = Serial.read();} //read keystrokes then back to loop
int getadcReading()
      int data;
      int deviceAdd = 0x48;   //ADS1115 address with address pin grounded
      Wire.beginTransmission(deviceAdd); // transmit to I2c device address
      Wire.send(0x00);                   // point to device register 0
      Wire.endTransmission();            // stop transmitting
      Wire.requestFrom(deviceAdd, 2);    // request 2 bytes from slave device #2
      while(Wire.available())    // need two bytes, MSB and LSB of converstion value
          data = Wire.receive();  //get MSB of reading
          data = data << 8;       // shift it to high byte of data
          data = data + Wire.receive(); // add LSB to data
      return data;
void setConfiguration()
            //uncomment desired voltage input range
      int confWord= 0x0000; topofScale = 6144;  // 0- 0-6.144 vdc range
      //int confWord= 0x0200; topofScale = 4096;  // 1= 0-4.096 vdc range
      //int confWord= 0x0400; topofScale = 2048;  // 2= 0-2.048 vdc range
      //int confWord= 0x0600; topofScale = 1024;  // 3= 0-1.024 vdc range
      //int confWord= 0x0800; topofScale =  512;  // 4= 0-.512 vdc range
      //int confWord= 0x0A00; topofScale =  256;  // 5= 0-.256 vdc range
           //uncomment desired channel input
               // Also this sets sample rate to 860 SPS, disables comparitor,
               // and turns on continous conversion mode.
      confWord = confWord | 0x00E3;  // 0= input wired to + AIN0 - AIN1, diff
      //confWord = confWord | 0x30E3;  // 3= input wired to + AIN2 - AIN3, diff
      //confWord = confWord | 0x40E3;  // 4= input wired to + AIN0 - gnd, single ended
      //confWord = confWord | 0x50E3;  // 5= input wired to + AIN1 - gnd, single ended
      //confWord = confWord | 0x60E3;  // 6= input wired to + AIN2 - gnd, single ended
      //confWord = confWord | 0x70E3 ; // 7= input wired to + AIN3 - gnd, single ended
      Wire.beginTransmission(deviceAdd); // transmit to ADS1115 device
      Wire.send(0x01);                   // point to configuration register
      Wire.send(highByte(confWord));      // sends MSB of configuration word
      Wire.send(lowByte(confWord));       // sends LSB of configuration word
Lefty
or you can try this TLV1543 data sheet, product information and support | TI.com its has 11 channels with 10bit resolution
hope this helps
Good luck with your research.
I updated my check sketch for the device to include enabling and testing the comparitor function. This lets you set a high limit and low limit and if the voltage is between them it sets a output pin low in one comparitor mode, or will go low if the voltage exceeds the high set limit or falls below the low limit, in the other comparitor mode.
/* Basic testing and check out sketch for a TI ADS1115 4 channel 16 bit I2C analog to digital converter chip.
   Reads voltage at desired range on desired channel and displays it on serial monitor. Also allows comparitor
   to output a active low signal pin if enabled.
   Leftyretro 08/10/11
#include <Wire.h>
int topofScale;          // global to use adc range value to display millivolt reading conversion
int hiCompair = 17000;   // high setting for comparitor threshold value, must be higher then loCompair 32767
int loCompair = 11000;   // low  setting for comparitor threshold value, must be lower then hiCompair -32768
    setadcConfiguration();  // configure ADS1115 chip for range, channel input, and comparitor options desired
    scaledValue = map(rawValue, 0, 32767, 0, topofScale);  //convert raw adc counts to millivolts
    while(Serial.available() > 0) {byte userKeys = Serial.read();} //read keystrokes
int getadcReading()   // read 16 bit analog voltage reading
      int data;
      int deviceAdd = 0x48;              // ADS1115 address with address pin grounded
          data = Wire.receive();         // get MSB of reading
      return data;
void setadcConfiguration()
            /* uncomment one desired voltage input range */
      int confWord= 0x0000; topofScale = 6144;  // +/-6.144 vdc range
      //int confWord= 0x0200; topofScale = 4096;  // +/-4.096 vdc range
      //int confWord= 0x0400; topofScale = 2048;  // +/-2.048 vdc range
      //int confWord= 0x0600; topofScale = 1024;  // +/-1.024 vdc range
      //int confWord= 0x0800; topofScale =  512;  // +/-.512 vdc range
      //int confWord= 0x0A00; topofScale =  256;  // +/-.256 vdc range
      /*  uncomment one desired channel input
          This also sets sample rate to 860 SPS and turns on continous conversion mode. */
      confWord = confWord | 0x00E0;  //input wired to + AIN0 - AIN1, diff +/- max range
      //confWord = confWord | 0x30E0;  //input wired to + AIN2 - AIN3, diff +/- max range
      //confWord = confWord | 0x40E0;  //input wired to + AIN0 - gnd, single ended, 0 to +max range
      //confWord = confWord | 0x50E0;  //input wired to + AIN1 - gnd, single ended, 0 to +max range
      //confWord = confWord | 0x60E0;  //input wired to + AIN2 - gnd, single ended, 0 to +max range
      //confWord = confWord | 0x70E0;  //input wired to + AIN3 - gnd, single ended, 0 to +max range
      /* uncomment one desired comparator options
         active low ready pin, window mode = input voltage is inside window values
         active low ready pin, traditional = voltage raised above or fell below set values */
      //confWord = confWord | 0x0003;   //disable comparitor
      //confWord = confWord | 0x0008;    //enable comparitor in traditional comparator mode
      confWord = confWord | 0x0018;   //enable comparitor in window comparator mode
      //send configuration word to device
      //send low threshold value word to device
      Wire.send(0x02);                    // point to low threshold register
      Wire.send(highByte(loCompair));     // sends MSB of low threshold word
      Wire.send(lowByte(loCompair));      // sends LSB of low threshold word
      //send high threshold value word to device
      Wire.send(0x03);                    // point to high threshold register
      Wire.send(highByte(hiCompair));     // sends MSB of high threshold word
      Wire.send(lowByte(hiCompair));      // sends LSB of high threshold word
Lefty
retrolefty, you are legendary.
seriously... I am a psych guy who randomly got thrown into HCI and hardware development ... and people like you (and many others in this forum) are teaching me so much ...
Thank you.
