Arduino Compiler and Variadic Macro Arguments
Does the Arduino compiler support ANY form of variadic macro arguments? I've tried a half dozen different formats for this, some of which were explicitly claimed to be unique to gnu c++, but NONE of them work.
Is there another form I'm missing?
Regards,
Ray L.
Should. I recall various people using them for debug stuff.
Post an example.
I've tried every variation I can find, including these:
#define BLORT1(s) { printf(s); }
#define BLORT2(...) { printf(VA_ARGS); }
#define BLORT3(s, ...) { printf(s, VA_ARGS); }
#define BLORT3(s, ...) { printf(s, ## VA_ARGS); }
#define BLORT4(s, args...) { printf(s, args); }
So far, NOTHING has worked.
Regards,
Ray L.
These work.
// DebugMacros.h
/* Example of use:
   #define DEBUG          // <-----<<<< this line must appear before the include line
   #include <DebugMacros.h>
//If you comment the line:  #define DEBUG
//The Macro lines are defined as blank, thus would be ignored by the compiler.
//If the line is NOT commented, these macros will be included in the sketch.
// examples:
// This  converts to         >>>>----->         This OR a Blank Line.
// DPRINTLN("Testing123");   >>>>----->     Serial.println("Testing123");
// DPRINTLN(0xC0FFEEul,DEC); >>>>----->     Serial.println(0xC0FFEEul,DEC);
// DPRINTLN(12648430ul,HEX); >>>------>     Serial.println(12648430ul,HEX);
// DPRINTLNF("This text came from flash");  Serial.println(F("This text came from flash"));
// DPRINT(myVariable);       >>>>----->     Serial.print(myVariable);
// DELAY(100);               >>>>----->     delay(100);
// SERIALBEGIN(9600);        >>>>----->     Serial.begin(9600);
// PINMODE(13,OUTPUT);       >>>>----->     pinMode(13,OUTPUT);
// TOGGLEd13;                >>>>----->     PINB = 0x20;  // D13 Toggle,for UNO ONLY
#ifdef DEBUG
//#define DPRINT(args...)  Serial.print(args)             //OR use the following syntax:
#define SERIALBEGIN(...)   Serial.begin(__VA_ARGS__)
#define DPRINT(...)        Serial.print(__VA_ARGS__)
#define DPRINTLN(...)      Serial.println(__VA_ARGS__)
#define DRINTF(...)        Serial.print(F(__VA_ARGS__))
#define DPRINTLNF(...)     Serial.println(F(__VA_ARGS__)) //Printing text using the F macro
#define DELAY(...)         delay(__VA_ARGS__)
#define PINMODE(...)       pinMode(__VA_ARGS__)
#define TOGGLEd13          PINB = 0x20                    //For the UNO only
#else
#define SERIALBEGIN(...)   //blank line
#define DPRINT(...)        //blank line
#define DPRINTLN(...)      //blank line
#define DPRINTF(...)       //blank line
#define DPRINTLNF(...)     //blank line
#define DELAY(...)         //blank line
#define PINMODE(...)       //blank line
#define TOGGLEd13          //blank line
#endif
Well.... This is annoying! I was getting spoofed. The first macro I created was:
#define INFO(...) { Console->printf("INFO: "); Console->printf(VA_ARGS); }
When I used it like this:
INFO("Blew Chunk in %s\n", s);
I got the error that INFO required one argument but I passed two.
Turns out, there was already a, INFO macro in one of the libraries that was over-riding mine! I changed mine from INFO to INFORM, and it now works!
Thanks!
Regards,
Ray L.
For some reason I have a recollection that a do/while eliminates a potential problem...
#define INFORM(...)  do { Console->printf("INFO: "); Console->printf(__VA_ARGS__); } while ( false )
The optimizer gladly eliminates the actual loop.
#define FOO(x) { ... }
if (blah) FOO(7);
else FOO(77);
expands to
if (blah) { ... };
else { ... };
which gives an "else without if" error. "do { ... } while (0)" will give proper syntax. Using { } with if and else will also avoid the problem.
