I used arduino compiler 1.0.5 under windows 7 where I compiled de code of the NODO-software succesfully.
Now I upgraded only the arduino compiler to the latest version 1.6.9 and the NODO code doesn't compile anymore.
I received errors in plugin_001 line 50 where stands
boolean Plugin_001(byte function, struct NodoEventStruct *event, char *string)
The error was not knowing boolean and byte What is the problem?
What I did in the past to get the nodo software up and running under the compiler 1.0.5 was:
I downloaded the Nodo software code from Downloads & links - Nodo Wiki (take the second one => Nodo versie V3.7 Build 744 ) and unzip everything under c:\nodo
copy the library from c:\nodo\library to the arduino compiler library
open the nodo source in the arduino compiler and go to the tab nodo, change SKETCH_PATH into c:\nodo and change #define CONFIG_FILE Config_10.c into #define CONFIG_FILE Config_01.c
Start compiling
Why doesn't this compile anymore in the new version? Is there a work around?
Thanks
Erwin
