mac OSX 10.7 (Lion) and Arduino IDE 1.0.5 for mac
I verbosed the compiler output and got:
/var/folders/k6/w0wrbkrn4tz32phz5cl0syx0000fs7/T/build597971112654782375.tmp/strandtest.cpp.elf
/var/folders/k6/w0wrbkrn4tz32phz5cl0syx0000fs7/T/build597971112654782375.tmp/strandtest.cpp.hex
Where do I point my finder to get to these files? There is no /var/folders directly off the root of my HDD.
(And, BTW... I plan on downloading these to a Wicked Devices Nanode 5 via sketchgarden. Is it likely to want the .hex file or the .elf file?)
Thank you for your insight and advice!
awardblvr:
The folder is there, it's just set invisible.
In the 'Go' menu of Finder select 'Go to Folder...' and paste in the folder path:
Os X:
First, close the arduino IDE and locate your preferences.txt in /Users//Library/Arduino/preferences.txt and change/add
build.path=/Users/<USERNAME>/Documents/Arduino/build
Of course, replace with your username. Make sure the folder exists.
awardblvr:
The .hex file is generally the one you feed to an uploader because that has the raw object code in it.
RobvdVeer:
You should be able to use the Unix shortcut:
build.path=~/Documents/Arduino/build
The ‘~’ (tilde?) means “the current user’s home directory”
johnwasser:
The '~' (tilde?) means "the current user's home directory"
Yes, indeed. What was i thinking!?
