arduino compiling error
hello I have got a problem with compiling a sketch.
I try to control an led with a remote but the decoder program will not compile
someone who knows how to do it ?
this is the error:
Arduino: 1.6.5 (Windows 8.1), Board:"Arduino Uno"
IRremote\IRremote.cpp.o: In function MATCH(int, int)': C:\Users\tom\Documents\Arduino\libraries\IRremote/IRremoteInt.h:176: multiple definition of MATCH(int, int)'
Ir_decoder.cpp.o:C:\Users\tom\Documents\Arduino\libraries\IRremote/IRremoteInt.h:176: first defined here
IRremote\IRremote.cpp.o: In function MATCH(int, int)': C:\Users\tom\Documents\Arduino\libraries\IRremote/IRremoteInt.h:176: multiple definition of MATCH_MARK(int, int)'
IRremote\IRremote.cpp.o: In function MATCH(int, int)': C:\Users\tom\Documents\Arduino\libraries\IRremote/IRremoteInt.h:176: multiple definition of MATCH_SPACE(int, int)'
collect2.exe: error: ld returned 1 exit status
error with compiling.
Do you have an Arduino robot? If not, delete C:\Users\tom\Documents\Arduino\libraries\IRremote/IRremoteInt.h and the corresponding cpp file.
Show your code, with code tags.
Looks like you incorrectly declared/defined MATCH_XXXX() so that the computer thinks there are more than one definition.
this is the code but what are code tags?
#include <IRremote.h>
#include <IRremoteInt.h>
int IRpin = 11;
IRrecv irrecv(IRpin);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  if (irrecv.decode(&results))
      Serial.println(results.value, DEC); // Print the Serial 'results.value'
      irrecv.resume();   // Receive the next value
Clearly you have not read the sticky posts at the top of the forum that you were supposed to read before posting here.
I'm sorry I will read them
code good now?
try removing this line:
wont work
error :
C:\Users\tom\Documents\Arduino\libraries\IRremote\IRremote.cpp:20:25: fatal error: IRremoteInt.h: No such file or directory
#include "IRremoteInt.h"
compilation terminated.
Multiple libraries were found for "IRremote.h"
Used: C:\Users\tom\Documents\Arduino\libraries\IRremote
Not used: C:\Users\tom\Documents\Arduino\libraries\IRremote623142
Fout bij compileren.
WHY do you have multiple libraries with the same name?
my mistake got it fixst
now I got this error:
Ir_decoder.ino:2:25: fatal error: IRremoteINT.h: No such file or directory
Does the IRremoteINT.h file actually exist? Where?
Mine is called IRremoteInt.h.
