cocas42
February 19, 2020, 1:09am
1
hi, i'm using "wiattend" (GitHub - abobija/wiattend: RFID Attendance System realized using MFRC522 and ESP32 ) from the base and I'm trying to adapt my own needs, but I don't know if it's possible.
I want to confirm lunch only if they have logs in the last 8 hours, how can I do it?
(I use this base to manage attendance and give clothes for the workday, but I want to authorize only if they have worked in the last 8 hours, these are two different locations!)
cocas42
February 19, 2020, 3:16am
2
for now, i do this:
<?php
$servername = "localhost";
$database = "wiattend";
$username = "root";
$password = "";
// Create connection
$conn = mysqli_connect($servername, $username, $password, $database);
// Check connection
if (!$conn) {
die("Connection failed: " . mysqli_connect_error());
$last = "SELECT *, DATE_FORMAT(NOW(), '%H:%i') as time FROM log WHERE tag_id=3 AND time > DATE_SUB(CURDATE(), INTERVAL 1 HOUR)";
$result = $conn->query($last);
if ($result->num_rows > 0) {
// output data of each row
while($row = $result->fetch_assoc()) {
echo "id: " . $row["tag_id"]. " - Hora: " . $row["time"]. "
echo "0 results";
mysqli_close($conn);
