Arduino Connecting to URL
Hi, I have recently started to teach myself Arduino programming. I am aiming to build my own vehicle simulator for use with the game ‘Euro Truck Simulator’
To achieve this I need to get data from the game to gauges and lights etc, so I though an Arduino would be the best way to do this.
The game has an API that broadcasts game variables via a JSON file.
This API is accessed via an ethernet server.
I have used the code below to successfully connect to the server port, but I am not sure what to do now to get to the JSON file.
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xBE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEC };
byte server[] = { 192, 168, 0, 13 }; // ETS2 Telemetry Server
int tcp_port = 25555;
EthernetClient client;
  Ethernet.begin(mac);
  Serial.println("Connecting...");
  if (client.connect(server, tcp_port)) { // Connection to ETS2 telemetry Server
    Serial.println("Connected to ETS2 Telemetry Server");
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    for(;;)
The full URL to get to the JSON data is: http://192,168.0.13:25555/api/ets2/telemetry
I have tried adding a GET command after connecting to the server but can’t seem to get the syntax right.
Hopefully someone can point me in right direction
aarontearle1:
may be this will get you in the right direction... :grin:
Thank you. I am well aware of how to us Google and before joining this forum I did, but couldn’t find a solution that worked - hence why I came here to ask the “experts”
