Hello people
I have a little problem. I need to connect the Arduino Mini Pro with an HC-06 Bluetooth.
input/outputs: Arduino HC-06
GND ------------------ G(GND)
VCC --------------------- V
D0(TX)-----------------2
D1(RX) -----------------3
I tried this code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
Serial.println("Goodnight moon!");
//mySerial.begin(115200); //if you change the baud and want to re-run this sketch, make sure this baud rate matches the new rate.
mySerial.begin(38400);
//mySerial.begin(9600);
mySerial.print("AT");
mySerial.print("AT+VERSION");
//delay(1000);
//mySerial.print("AT+PIN1234"); // Set pin to 1234 was 1342
//delay(1000);
//mySerial.print("AT+NAMEJY-MCU-HC06"); // Set the name to JY-MCU-HC06
//mySerial.print("AT+BAUD8"); // Set baudrate to 115200
//mySerial.print("AT+BAUD4"); // Set baudrate to 9600
//mySerial.print("AT+BAUD7"); // Set baudrate to 57600
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
But, i can not to get the ok. Can you help me? Thank you.
