Ciao a tutti!
Avrei bisogno di una grande mano... vorrei creare un programmino che collegato allo schermo lcd 16x2, nella prima riga presenti una scritta e nella seconda un contatore di quante volte viene premuto un pulsante collegato anch'esso ad arduino...
Ho già questo come base :
#include <SoftwareSerial.h> //for software serial communication
#define txPin 14 //change to your serial port on Arduino board
#define rxPin 15 //not used but is required
SoftwareSerial mySerial = SoftwareSerial(rxPin, txPin);
int buttonPressCount;
const int buttonPin = 2; //the pin that the pushbutton is attached to
int buttonPushCounter = 0; //counter for the number of button presses
int buttonState = 0; //current state of the button
int lastButtonState = 0; //previous state of the button
pinMode(buttonPin, INPUT); //initialize the button pin as a input
Serial.begin(9600); //initialize serial communication
pinMode(txPin, OUTPUT);
//the following resets the board, changes the brightness to 100%, and sets the board to '0000':
mySerial.begin(9600);
mySerial.print(0x7A,BYTE); //special character
mySerial.print(0x00,BYTE); //set brightness to full
mySerial.print(0x76,BYTE); //reset board
mySerial.print(0); //send '0' character
void loop(){
buttonState = digitalRead(buttonPin); //read the pushbutton input pin
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// went from off to on:
buttonPushCounter++;
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter, DEC);
updateDisplay(buttonPushCounter); //function to update the display 'requires button press count'
lastButtonState = buttonState; // save the current state as the last state, for next time through the loop
void updateDisplay(int buttonPushCounter){
String intString = String(buttonPushCounter); //changes integer to a string
char displayChars[4]; //create array to hold the four numbers
int stringLength = intString.length(); //get length of the string
//the following will determine if the button press count variable has 1, 2, 3, or 4 numbers in it
//and will fill the empty spaces with '0'. so if the button press count variable is '29' it will end up being '0029':
if(stringLength == 4){
displayChars[0] = intString.charAt(0);
displayChars[1] = intString.charAt(1);
displayChars[2] = intString.charAt(2);
displayChars[3] = intString.charAt(3);
}else if(stringLength == 3){
displayChars[0] = 0;
displayChars[1] = intString.charAt(0);
displayChars[2] = intString.charAt(1);
displayChars[3] = intString.charAt(2);
}else if(stringLength == 2){
displayChars[1] = 0;
displayChars[2] = intString.charAt(0);
displayChars[3] = intString.charAt(1);
}else if(stringLength == 1){
displayChars[2] = 0;
displayChars[3] = intString.charAt(0);
mySerial.print(0x76,BYTE); //Reset board
mySerial.print(displayChars[0]); //Send '0' character
mySerial.print(displayChars[1]); //Send '0' character
mySerial.print(displayChars[2]); //Send '0' character
mySerial.print(displayChars[3]); //Send '0' character
delay(100); //this will make it so you don't get double counts. you could also use this to avoid someone pressing the button repeatedly 'for fun!'
Ma questo me lo manda nel serial monitor... come posso fare ? Vi ringrazio anticipatamente!
