Hello all,
I'm using Arduino to control Faulhaber AM1020 stepper motors. My set up is the following:
- Arduino UNO board
- CNC shield
- DRV8825 drivers
- Faulhaber AM1020 stepper motors
- Windows 7 computer
I have a code (attached) that can control motors via serial communication. My issue is that this code works with some standard stepper motors (SM-17HS4023), but when I change them to the Faulhaber ones, they don't move. When I hold them with my hands I can feel and hear the noise of the pulses as if they were moving, but they are not. I don't know what should I change in order to make my code suitable for these motors.
I'm also uploading the manual for these motors, in case it helps.
PS. The code is written to move to motors in the position X and A of the shield, but I'm planning to use all the positions X,Y,Z and A. This is just for trial.
#include <SoftwareSerial.h>
#include <AccelStepper.h>
const byte numChars = 32; //number of characters per piece of info
char receivedChars[numChars];
char tempChars[numChars]; //temporary array for use when parsing
float xsteps = 0.0;
float asteps = 0.0;
boolean newdata = false;
//two stepper motors
#define xenable 8
#define xstep 2 //pin for step of x motor
#define xdir 5 //pin for dir of x motor
AccelStepper xmotor(1, xstep, xdir);
#define aenable 8
#define astep 12 //pin for step of y motor
#define adir 13 //pin for dir of y motor
AccelStepper amotor(1, astep, adir);
Serial.println("input data");
pinMode(xenable, OUTPUT);
pinMode(aenable, OUTPUT);
xmotor.setEnablePin(xenable);
xmotor.setPinsInverted(false, false, true);
xmotor.setAcceleration(1);
xmotor.setMaxSpeed(10);
//motorX.setSpeed(100);
xmotor.enableOutputs();
amotor.setEnablePin(aenable);
amotor.setPinsInverted(false, false, true);
amotor.setAcceleration(1);
amotor.setMaxSpeed(10);
//motorY.setSpeed(100);
amotor.enableOutputs();
receive();
if (newdata == true) {
strcpy(tempChars, receivedChars); //this copies the values in recerivedchars into tempchars (string) for a temporary copy
parsedata();
showpd(); //show parsed data
newdata = false;
xmotor.moveTo(xsteps);
amotor.moveTo(asteps);
xmotor.run();
amotor.run();
//======= define the used functions======
//receiving (and stop receiving) the data
void receive() {
static boolean rip = false; //receive in process
static byte ndx = 0;
char startmarker = '<'; //character that will mark the start of the reading by the serial monitor (i need to send the characters like that from labview)
char endmarker = '>'; //the same but with the end of the reading
char rc;
while (Serial.available() > 0 && newdata == false) { //check to see if anything is available in the serial receive buffer
rc = Serial.read(); // we add to the array the characters until the endmarker
if (rip == true) {
if (rc != endmarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
receivedChars[ndx] = '\0'; //terminate the string
rip = false;
ndx = 0;
newdata = true;
} else if (rc == startmarker) {
rip = true;
//split the data into the different parts -> depending in how many characters and what kind of characters we are sending
//this function will change
//we are getting in principle 4 sets of steps data (although we will try first with two) that are supposed to be float type
void parsedata() {
char* strtokindx; //use as an index for the strtok funtion
strtokindx = strtok(tempChars, ","); //get the first part
xsteps = atof(strtokindx); //converts this to a float
strtokindx = strtok(NULL, ","); //continues where the previous call left
asteps = atof(strtokindx);
//show what we have received (that serves as a confirmation that we did receive it or at least i think and hope so)
void showpd() { //show parsed data
Serial.print("X motor steps: ");
Serial.print(xsteps);
Serial.print("; A motor steps: ");
Serial.print(asteps);
basics.pdf (1.0 MB)
EN_AM1020_FPS.pdf (237.2 KB)
