Arduino Control Relay code
Hi everybody
I am a novice, and also an apprentice with ardruino, currently I have a code and a sample test software, when I program to relay close in the order. Only Relay No. 1 is OK, and the other relay when closed, immediately back to close Relay No. 1. I do not know how to handle the code is looking forward to the help of everyone. thank you
My code is as follows
void setup () {
Serial.begin (9600);
#define replay1 12
#define replay2 7
#define replay3 8
#define replay4 9
pinMode (replay1, OUTPUT);
digitalWrite (replay1, HIGH);
pinMode (replay2, OUTPUT);
digitalWrite (replay2, HIGH);
pinMode (replay3, OUTPUT);
digitalWrite (replay3, HIGH);
pinMode (replay4, OUTPUT);
digitalWrite (replay4, HIGH);
void loop () {
if (Serial.available ()> = 0) {
char c = Serial.read ();
Serial.println (c); // Test th? k? t? print out right
if (c == ‘1’) // value? click here to view lamp 1 s? light up, the other two lights?
digitalWrite (replay1, LOW);
delay (2000);
if (c == ‘2’) // value? Click on 2 lamp 2 s? light up, 2 lights
digitalWrite (replay2, LOW);
delay (2000);
if (c == ‘3’) // value? click on 3 lamp 3 s? light up, 2 lights
digitalWrite (replay3, LOW);
delay (2000);
if (c == ‘4’) ////? Click on the 4 th? 4 s lights? light up, 3 lights
digitalWrite (replay4, LOW);
delay (2000);
Here is your code formatted better and in code tags
void setup ()
#define replay1 12
#define replay2 7
#define replay3 8
#define replay4 9
void loop ()
  if (Serial.available () > = 0)
    if (c == '1') // value? click here to view lamp 1 s? light up, the other two lights?
      delay (2000);
      if (c == '2') // value? Click on 2 lamp 2 s? light up, 2 lights
        delay (2000);
      if (c == '3') // value? click on 3 lamp 3 s? light up, 2 lights
        delay (2000);
      if (c == '4') ////? Click on the 4 th? 4 s lights? light up, 3 lights
        delay (2000);
Which lines of code should be executed if c equals '1' ?
Why are the #defines in the setup() function and not at the start of the program ?
Please edit your post and use code tags
Type ``` [code] ``` before your code Type ``` [/code] ``` after your code
Further your code does not compile; you're missing a } at the end of the code (or elsewhere) and it's '>=' instead of '> =' (IDE 1.8.5).
What are #defines doing in setup? Although the compiler seems to be happy with it, they belong near the top of the code.
Instead of posting a screenshot, it would probably have been better if you would have posted a schematic how everything is connected (photo/scan of hand-drawn one is fine).
Next, from your code
void loop () {
  if (Serial.available () >= 0) {
What do you think that the chances are that if c equals '1', it will also be equal to '2', '3' or whatever.
