Arduino control the 2.4" TFT LCD
Useing the 2.4 inch TFT LCD , which is used ILI9325 controller , 65K color , 320*240 (resolution).
Connect the pins to Arduino DB0-DB16 to pin D0-D13 , pin A0-A1 of Arduino RESET to A2 CS to A3 WR to A4 RS to A5
Use the 16 bit data bus which is 2 timer faster than 8 bit. but it used up all the pins of the Arduino.
#define LCD_RS 19
#define LCD_REST 16
#define LCD_WR 18
#define LCD_CS 17
void main_Write_COM(int DH)
  unsigned char i;
  int temp;
  digitalWrite(LCD_RS,LOW);
  digitalWrite(LCD_CS,LOW);
  for(i=0;i<16;i++)
    temp=(DH&0x01);
    if(temp)
      digitalWrite(i,HIGH);
      digitalWrite(i,LOW);
    DH=DH>>1;
  digitalWrite(LCD_WR,LOW);
  digitalWrite(LCD_WR,HIGH);
  digitalWrite(LCD_CS,HIGH);
void main_Write_DATA(int DH)
  unsigned char i;
  int temp;
  digitalWrite(LCD_RS,HIGH);
  for(i=0;<16;i++)
    temp=(DH&;0x01);
    if(temp)
    DH=DH>>1;
void main_W_com_data(int com1,int dat1)
  main_Write_COM(com1);
  main_Write_DATA(dat1);
void address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
  main_W_com_data(0x0002,x1>>8);     // Column address start2
  main_W_com_data(0x0003,x1);    // Column address start1
  main_W_com_data(0x0004,x2>>8);     // Column address end2
  main_W_com_data(0x0005,x2);    // Column address end1
  main_W_com_data(0x0006,y1>>8);     // Row address start2
  main_W_com_data(0x0007,y1);    // Row address start1
  main_W_com_data(0x0008,y2>>8);     // Row address end2
  main_W_com_data(0x0009,y2);    // Row address end1
  main_Write_COM(0x0022);
void main_init(void)
  digitalWrite(LCD_REST,HIGH);
  delay(5);
  digitalWrite(LCD_REST,LOW);
  delay(10);
  delay(20);
  //  VENDOR
  main_W_com_data(0x0046,0x00A4);
  main_W_com_data(0x0047,0x0053);
  main_W_com_data(0x0048,0x0000);
  main_W_com_data(0x0049,0x0044);
  main_W_com_data(0x004a,0x0004);
  main_W_com_data(0x004b,0x0067);
  main_W_com_data(0x004c,0x0033);
  main_W_com_data(0x004d,0x0077);
  main_W_com_data(0x004e,0x0012);
  main_W_com_data(0x004f,0x004C);
  main_W_com_data(0x0050,0x0046);
  main_W_com_data(0x0051,0x0044);
  //240x320 window setting
  main_W_com_data(0x0002,0x0000); // Column address start2
  main_W_com_data(0x0003,0x0000); // Column address start1
  main_W_com_data(0x0004,0x0000); // Column address end2
  main_W_com_data(0x0005,0x00ef); // Column address end1
  main_W_com_data(0x0006,0x0000); // Row address start2
  main_W_com_data(0x0007,0x0000); // Row address start1
  main_W_com_data(0x0008,0x0001); // Row address end2
  main_W_com_data(0x0009,0x003f); // Row address end1
  // Display Setting
  main_W_com_data(0x0001,0x0006); // IDMON=0, INVON=1, NORON=1, PTLON=0
  main_W_com_data(0x0016,0x00C8); // MY=0, MX=0, MV=0, ML=1, BGR=0, TEON=0   0048
  main_W_com_data(0x0023,0x0095); // N_DC=1001 0101
  main_W_com_data(0x0024,0x0095); // PI_DC=1001 0101
  main_W_com_data(0x0025,0x00FF); // I_DC=1111 1111
  main_W_com_data(0x0027,0x0002); // N_BP=0000 0010
  main_W_com_data(0x0028,0x0002); // N_FP=0000 0010
  main_W_com_data(0x0029,0x0002); // PI_BP=0000 0010
  main_W_com_data(0x002a,0x0002); // PI_FP=0000 0010
  main_W_com_data(0x002C,0x0002); // I_BP=0000 0010
  main_W_com_data(0x002d,0x0002); // I_FP=0000 0010
  main_W_com_data(0x003a,0x0001); // N_RTN=0000, N_NW=001    0001
  main_W_com_data(0x003b,0x0000); // P_RTN=0000, P_NW=001
  main_W_com_data(0x003c,0x00f0); // I_RTN=1111, I_NW=000
  main_W_com_data(0x003d,0x0000); // DIV=00
  delay(1);
  main_W_com_data(0x0035,0x0038); // EQS=38h
  main_W_com_data(0x0036,0x0078); // EQP=78h
  main_W_com_data(0x003E,0x0038); // SON=38h
  main_W_com_data(0x0040,0x000F); // GDON=0Fh
  main_W_com_data(0x0041,0x00F0); // GDOFF
  // Power Supply Setting
  main_W_com_data(0x0019,0x0049); // CADJ=0100, CUADJ=100, OSD_EN=1 ,60Hz
  main_W_com_data(0x0093,0x000F); // RADJ=1111, 100%
  delay(1);
  main_W_com_data(0x0020,0x0040); // BT=0100
  main_W_com_data(0x001D,0x0007); // VC1=111   0007
  main_W_com_data(0x001E,0x0000); // VC3=000
  main_W_com_data(0x001F,0x0004); // VRH=0011
  //VCOM SETTING
  main_W_com_data(0x0044,0x004D); // VCM=101 0000  4D
  main_W_com_data(0x0045,0x000E); // VDV=1 0001   0011
  delay(1);
  main_W_com_data(0x001C,0x0004); // AP=100
  delay(2);
  main_W_com_data(0x001B,0x0018); // GASENB=0, PON=0, DK=1, XDK=0, VLCD_TRI=0, STB=0
  delay(1);
  main_W_com_data(0x001B,0x0010); // GASENB=0, PON=1, DK=0, XDK=0, VLCD_TRI=0, STB=0
  delay(1);
  main_W_com_data(0x0043,0x0080); //set VCOMG=1
  delay(2);
  // Display ON Setting
  main_W_com_data(0x0090,0x007F); // SAP=0111 1111
  main_W_com_data(0x0026,0x0004); //GON=0, DTE=0, D=01
  delay(1);
  main_W_com_data(0x0026,0x0024); //GON=1, DTE=0, D=01
  main_W_com_data(0x0026,0x002C); //GON=1, DTE=0, D=11
  delay(1);
  main_W_com_data(0x0026,0x003C); //GON=1, DTE=1, D=11
  // INTERNAL REGISTER SETTING
  main_W_com_data(0x0057,0x0002); // TEST_Mode=1: into TEST mode
  main_W_com_data(0x0095,0x0001); // SET DISPLAY CLOCK AND PUMPING CLOCK TO SYNCHRONIZE
  main_W_com_data(0x0057,0x0000); // TEST_Mode=0: exit TEST mode
  //main_W_com_data(0x0021,0x0000);
void Pant(unsigned int color)
  int i,j;
  address_set(0,0,239,319);
  for(i=0;i<320;i++)
    for (j=0;j<240;j++)
      main_Write_DATA(color);
  unsigned char p;
  for(p=0;p<20;p++)
    pinMode(p,OUTPUT);
  main_init();
  Pant(0xf800); //Red
  Pant(0X07E0); //Green
  Pant(0x001f); //Blue
More information about the demo code and the screen : http://iteadstudio.com/application-note/itdb02-2-4-display-with-arduino
I am going to write a library for this controller , and there are the 2.4 and 3.2 inch LCD use the same controller that can use this library ;)
Rats. Going by the thread title, I was hoping to find a LARGE TFT that I could use in a project.
Haha I didn't notice the 2.4 foot in the title! ;D
Well at least there are a load of these 2.4" displays hanging around now to choose from. This place looks pretty cheap though. I wonder how much international shipping to UK is...
Mowcius
The fact that is uses up every I/O pin on a standard Arduino kind of limits it's application doesn't it? ;)
Plan on using a Mega board if you are going to the trouble of writing a library for it, otherwise it's kind of useless, no?
Lefty
meh
I would use an rDuino LEDhead which is standard arduino form factor but has extra pin pads on the board as it uses an 644 chip :)
Mowcius
It's a Low-level errors... 2.4“ GLCD ;)
The fact that is uses up every I/O pin on a standard Arduino kind of limits it’s application doesn’t it?
Plan on using a Mega board if you are going to the trouble of gifwriting a library for it, otherwise it’s kind of useless, no?
Arduino really with a pool resources of I/O … so 16bit will use up all the pins of Arduino , if you want to use the touch and the SD card , then just can choose the 8bit mode – which more slower than you can imagine :frowning: Mega has enough I/O for the LCD ,touch , SDcard even the external flash .
Even in the 16bit mode work in 16M , the refresh rate is not faster than 1 frame per second … so you can used the arduino to show the UI menu or a static image , but the video beyond its capacity – STM32 is a good choice, I like the DMA :wink:
#define LCD_RS 8
#define LCD_WR 9
#define LCD_CS 10
#define LCD_REST 11
void LCD_Writ_Bus(char VH,char VL)
    unsigned char i,temp,data;
    data=VH;
     for(i=0;i<8;i++)
       temp=(data&0x01);
       if(temp)
       data=data>>1;
    data=VL;
    for(i=0;i<8;i++)
       temp=(data&0x01);
       if(temp)
       data=data>>1;
void LCD_Write_COM(char VH,char VL)
    LCD_Writ_Bus(VH,VL);
void LCD_Write_DATA(char VH,char VL)
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
    LCD_Write_COM(0x00,0x20);LCD_Write_DATA(x1>>8,x1);
    LCD_Write_COM(0x00,0x21);LCD_Write_DATA(y1>>8,y1);
    LCD_Write_COM(0x00,0x50);LCD_Write_DATA(x1>>8,x1);
    LCD_Write_COM(0x00,0x52);LCD_Write_DATA(y1>>8,y1);
    LCD_Write_COM(0x00,0x51);LCD_Write_DATA(x2>>8,x2);
    LCD_Write_COM(0x00,0x53);LCD_Write_DATA(y2>>8,y2);
    LCD_Write_COM(0x00,0x22);
void LCD_Init(void)
    delay(5);
    delay(5);
    delay(5);
    //************* Start Initial Sequence **********//
    LCD_Write_COM(0x00,0xE5); LCD_Write_DATA(0x78,0xF0); // set SRAM internal timing
    LCD_Write_COM(0x00,0x01); LCD_Write_DATA(0x01,0x00); // set SS and SM bit
    LCD_Write_COM(0x00,0x02); LCD_Write_DATA(0x07,0x00); // set 1 line inversion
    LCD_Write_COM(0x00,0x03); LCD_Write_DATA(0x10,0x30); // set GRAM write direction and BGR=1.
    LCD_Write_COM(0x00,0x04); LCD_Write_DATA(0x00,0x00); // Resize register
    LCD_Write_COM(0x00,0x08); LCD_Write_DATA(0x02,0x07); // set the back porch and front porch
    LCD_Write_COM(0x00,0x09); LCD_Write_DATA(0x00,0x00); // set non-display area refresh cycle ISC[3:0]
    LCD_Write_COM(0x00,0x0A); LCD_Write_DATA(0x00,0x00); // FMARK function
    LCD_Write_COM(0x00,0x0C); LCD_Write_DATA(0x00,0x00); // RGB interface setting
    LCD_Write_COM(0x00,0x0D); LCD_Write_DATA(0x00,0x00); // Frame marker Position
    LCD_Write_COM(0x00,0x0F); LCD_Write_DATA(0x00,0x00); // RGB interface polarity
    //*************Power On sequence ****************//
    LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x00,0x00); // SAP, BT[3:0], AP, DSTB, SLP, STB
    LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x00,0x07); // DC1[2:0], DC0[2:0], VC[2:0]
    LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x00); // VREG1OUT voltage
    LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x00,0x00); // VDV[4:0] for VCOM amplitude
    LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x00,0x01);
    delay(50); // Dis-charge capacitor power voltage
    LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x10,0x90); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB
    LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x02,0x27); // DC1[2:0], DC0[2:0], VC[2:0]
    delay(50); // Delay 50ms
    LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x1F); //001C// Internal reference voltage= Vci;
    LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x15,0x00); //0x1000//1400   Set VDV[4:0] for VCOM amplitude  1A00
    LCD_Write_COM(0x00,0x29); LCD_Write_DATA(0x00,0x27); //0x0012 //001a  Set VCM[5:0] for VCOMH  //0x0025  0034
    LCD_Write_COM(0x00,0x2B); LCD_Write_DATA(0x00,0x0D); // Set Frame Rate   000C
    LCD_Write_COM(0x00,0x20); LCD_Write_DATA(0x00,0x00); // GRAM horizontal Address
    LCD_Write_COM(0x00,0x21); LCD_Write_DATA(0x00,0x00); // GRAM Vertical Address
    // ----------- Adjust the Gamma Curve ----------//
    LCD_Write_COM(0x00,0x30); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x31); LCD_Write_DATA(0x07,0x07);
    LCD_Write_COM(0x00,0x32); LCD_Write_DATA(0x03,0x07);
    LCD_Write_COM(0x00,0x35); LCD_Write_DATA(0x02,0x00);
    LCD_Write_COM(0x00,0x36); LCD_Write_DATA(0x00,0x08);//0207
    LCD_Write_COM(0x00,0x37); LCD_Write_DATA(0x00,0x04);//0306
    LCD_Write_COM(0x00,0x38); LCD_Write_DATA(0x00,0x00);//0102
    LCD_Write_COM(0x00,0x39); LCD_Write_DATA(0x07,0x07);//0707
    LCD_Write_COM(0x00,0x3C); LCD_Write_DATA(0x00,0x02);//0702
    LCD_Write_COM(0x00,0x3D); LCD_Write_DATA(0x1D,0x04);//1604
    //------------------ Set GRAM area ---------------//
    LCD_Write_COM(0x00,0x50); LCD_Write_DATA(0x00,0x00); // Horizontal GRAM Start Address
    LCD_Write_COM(0x00,0x51); LCD_Write_DATA(0x00,0xEF); // Horizontal GRAM End Address
    LCD_Write_COM(0x00,0x52); LCD_Write_DATA(0x00,0x00); // Vertical GRAM Start Address
    LCD_Write_COM(0x00,0x53); LCD_Write_DATA(0x01,0x3F); // Vertical GRAM Start Address
    LCD_Write_COM(0x00,0x60); LCD_Write_DATA(0xA7,0x00); // Gate Scan Line
    LCD_Write_COM(0x00,0x61); LCD_Write_DATA(0x00,0x01); // NDL,VLE, REV
    LCD_Write_COM(0x00,0x6A); LCD_Write_DATA(0x00,0x00); // set scrolling line
    //-------------- Partial Display Control ---------//
    LCD_Write_COM(0x00,0x80); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x81); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x82); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x83); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x84); LCD_Write_DATA(0x00,0x00);
    LCD_Write_COM(0x00,0x85); LCD_Write_DATA(0x00,0x00);
    //-------------- Panel Control -------------------//
    LCD_Write_COM(0x00,0x90); LCD_Write_DATA(0x00,0x10);
    LCD_Write_COM(0x00,0x92); LCD_Write_DATA(0x06,0x00);
    LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x01,0x33); // 262K color and display ON
void Pant(char VH,char VL)
    int i,j;
    Address_set(0,0,240,320);
    for(i=0;i<320;i++)
      for (j=0;j<240;j++)
             LCD_Write_DATA(VH,VL);
  unsigned char p;
  int i,j,k;
  for(p=0;p<20;p++)
    pinMode(p,OUTPUT);
    LCD_Init();
   Pant(0xf8,0x00);
   Pant(0x07,0xE0);
   Pant(0x00,0x1f);
The code for 8 bit mode~ connect the DB9-DB16 to the Arduino D0-D7 . pull the DB1-DB8 to GND.
The same effect as the 16bit mode , but slower than 16bit mode , if you use the 8M 3.3V Arduino Pro , about 3 seconds one frame… but now you have the pins for SD card and the Touch.
Update : now we release a library for the 2.4"LCD module , now the beta version just support the LCD display and not powerful enough ,the V1.0 will include more GUI functions and will support touch screen.
Google Code project : http://code.google.com/p/itdb02
This is awesome! Nice work! [smiley=thumbsup.gif] It's over $120 less than the liquidware touchscreen slide, even if it is less developed/supported. :)
:question I just ordered the 3.2" screen for my own development. You said that one was supported as well with your library, correct? :question
blueblur22: You could also take a look at my libraries for these modules: http://www.henningkarlsen.com/electronics/a_l_itdb02_graph16.php
/Henning
Looks interesting. I'll give this one a try when the screen shows up in the mail. Thanks!
EDIT: Wait... no support for the SD and the Flash? I will be needing both of these for my project as i need to use many graphics. Large storage will be needed. Any way to make this happen? Does anybody else have another library that supports both?
Not really unless you switch to a Mega. The arduino does not really have the resources.
Sorry, I thought I mentioned it. I am using the Mega1280. Forgot that bit.
I am working on support for the SD as well, but it is a long way away from being finished. My libraries does not stop you from using SD or flash in any way, so you still can use other libraries.
I am not sure if my modules even has flash on them :-?
/Henning
“As of v2.0 there are NO support for the SD card-slot or Flash-memory.”
Since you specificly mentioned there was no support for flash, I only assumed they all had it. What ever. I’m new to Arduino. I have experience for the Dragon board (RS232 chip set) and am basing everything off of that.
I don’t know why I assumed I could only use one library [smiley=embarassed.gif]
I just re-read the product pages at ITead, and the way I understand it is that all the modules support a SST25VF016B Flash-chip, but you supply it and solder it on yourself.
I have ordered some samples from Microchip, so maybe there will be support for them in the future ;)
The text on my website is based on the product description at ITead, but I feel that their description is a bit unclear regarding the flash memory.
/Henning
@doc_norway
I have been playing around with your library for a good week now. It's nice.
I do have a question at this point: How did you make the larger font? I looked into the small & large font files which are encoded in hex. Did you use some software/font editor to make this possible? Or did you make the font manually?
The reason I ask is because I want to make a font of my own for my project. I would be happy to share the results with the community, but need a little help getting started.
@blueblur22
I am glad you like my library.
The small font was taken directly from the library made by ITead, so I do not know how it was made.
When making the large font I did actually calculate all the values manually :)
Due to the limited memory on the Arduino, I would not recommend adding another font, but feel free to replace the exitsting ones. If you require other sizes than 8x12 or 16x16 you will have to make alteration to the print-functions as well.
If you need help with the format of the files/arrays, please let me know.
/Henning
In view of the slowness of the display wouldn't it be an idea to use serial-in parallel-out shift registers? Then all you need is one output for data, one for clock and one for enable (or whatever the display need to read the data).
Then again, are there any spi-parallel chips?
I can't see why it would be an improvment to make a serial interface to these displays. It would only slow down transfer even further. The speed is not limited by the display, but by the ATmegas ability to push data to the display.
That being said, I have been toying with an idea to make a hardware accelerator for the displays :o It is still in the idea-stage, so don't get you hopes up...
/Henning
