So im bout 1/2 way through my RGB desk lamp build. I have some programming experience, and feel im doing a decent job.
In the spirit of learning, i have posted my code for others to see! I hope to accomplish 2 things with this. I hope new coders can learn from my code, but most of all, i was hoping a more experience code than myself, could teach me a few things!
With that, here is my little arduino script, in code tags
edit: sp error(s)
Edit: Code may be a bit messy, but i wrote it in about an hour, and realize i still have ALOT of cleaning house to do!
Just wanted to point out, my lamp works as expected im very happy with the power if this tiny arduino! (uno r3)
int REDPIN=10;
int GREENPIN=9;
int BLUEPIN=11;
int micPin = A0;
int micValue = 0;
int mic_avg = 0; //better audio
int potPin = A1;
int potValue = 0;
int r=random(3);
int g=random(3);
int b=random(3);
int r_p=10;
int b_p=10;
int g_p=10;
int f_r=1;
int f_g=1;
int f_b=1;
int r_h=0;
int g_h=0;
int b_h=0;
int hold=0;
int mode=0;
int max_mode=5;
int hit=0;
int power_button = 2; // the number of the pushbutton pin
int mode_button = 4; // the number of the pushbutton pin
int power=1;
int pressed=0;
int buttonState=0;
int timer=0;
int change=100;
int speaker_pin=6;
float dub=1.3; //super hit
///auto calibrate stuff
int cal_avg =0;
int hit_counter=0;
int hit_thresh=2;
int no_hit_counter=0;
int no_hit_thresh=20;
int i;//sound
int n_pitch;//sound
int n_r;//sound
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
pinMode(speaker_pin, OUTPUT);
pinMode(power_button, INPUT);
calibrate();
buttonState = digitalRead(power_button);
if (buttonState == HIGH) {
if (pressed==0){
pressed=1;
if (power==-1){
power=1;
else{
power=-1;
beep_on();
if (buttonState == LOW) {
if (pressed==1) {
pressed=0;
beep_off();
buttonState = digitalRead(mode_button);
if (pressed==0){
pressed=1;
mode=(mode+1);
if (mode>max_mode){
mode=0;
beep_on();
flash_mode();
if (pressed==1) {
pressed=0;
beep_off();
get_audio();//gets audio from mic. sets hit to 1 or 0
if (mode==0){
if (hit==1){
random_color();
if (mode==1)
if (micValue>(potValue*dub)){
random_color();
r=(r+((micValue/22)*f_r));
g=(g+((micValue/21)*f_g));
b=(b+((micValue/20)*f_b));
if (r>255){
r=255;
f_r=-1;
if (g>255){
g=255;
f_g=-1;
if (b>255){
b=255;
f_b=-1;
if (r<0){
r=0;
f_r=1;
if (g<0){
g=0;
f_g=1;
if (b<0){
b=0;
f_b=1;
if (mode==2)
r_h=random(255);
g_h=random(255);
b_h=random(255);
if (hit==1){
r=0;
g=0;
b=0;
}//r=r_h; g=g_h; b=b_h;
r=r+((r_h-r)/50);
g=g+((g_h-g)/50);
b=b+((b_h-b)/50);
if (r>255){
r=255;
f_r=-1;
if (g>255){
g=255;
f_g=-1;
if (b>255){
b=255;
f_b=-1;
if (mode==3)
potValue=analogRead(potPin);
r=(r+((potValue/110)*f_r));
g=(g+((potValue/120)*f_g));
b=(b+((potValue/101)*f_b));
if (r>255){
r=255;
f_r=-1;
if (g>255){
g=255;
f_g=-1;
if (b>255){
b=255;
f_b=-1;
if (r<0){
r=0;
f_r=1;
if (g<0){
g=0;
f_g=1;
if (b<0){
b=0;
f_b=1;
if (mode==4)
r_h=random(255);
g_h=random(255);
b_h=random(255);
if (hit==1){
r=(r-(micValue*5));
g=(g-(micValue*5));
b=(b-(micValue*5));
r=r+((r_h-r)/150);
g=g+((g_h-g)/150);
b=b+((b_h-b)/150);
if (r<0){
r=0;
if (g<0){
g=0;
if (b<0){
b=0;
if (r>255){
r=255;
if (g>255){
g=255;
if (b>255){
b=255;
if (power==-1){
r=0;
g=0;
b=0;
color_write();
////////////END LOOP!!!!
void beep_on()
i=0;
n_pitch=213;
n_r=(50000/n_pitch);
for (i = 0; i < n_r; i++)
analogWrite(speaker_pin, 255);
delayMicroseconds(n_pitch);
analogWrite(speaker_pin, 0);
void beep_off()
i=0;
n_pitch=196;
void get_audio()
//potValue = map(analogRead(potPin),0,1024,0,1024);
hit=0;
Serial.print("Mode:");
Serial.print(mode);
Serial.print(":___:");
Serial.print("Cal:");
Serial.print(potValue);
mic_avg=0;
for (i = 0; i < 20; i++)
mic_avg = (mic_avg+analogRead(micPin));
mic_avg=(mic_avg/20);
micValue =mic_avg;
Serial.print("Mic:");
Serial.print(micValue);
if (micValue>potValue){
Serial.print("(B)");
hit=1;
no_hit_counter=0;
hit_counter=(hit_counter+1);
else{
Serial.print("");
hit_counter=0;
no_hit_counter=(no_hit_counter+1);
if (hit_counter>hit_thresh){
calibrate();
hit_counter=0;
if (no_hit_counter>no_hit_thresh){
calibrate();
no_hit_counter=0;
Serial.print("(D)");
void random_color()
r=random(255);
g=random(255);
b=random(255);
if (random(100)>90){
r=0;
g=0;
b=0;
void color_write()
analogWrite(REDPIN, r);
analogWrite(BLUEPIN, b);
analogWrite(GREENPIN, g);
void flash_mode()
r_h=r;
g_h=g;
b_h=b;
r=0;
g=0;
b=0;
if (mode==0){
color_write();
delay(100);
r=255;
color_write();
delay(300);
r=0;
color_write();
delay(10);
if (mode==1){
color_write();
delay(100);
g=255;
color_write();
delay(300);
r=0;
color_write();
delay(10);
if (mode==2){
color_write();
delay(100);
b=255;
color_write();
delay(300);
r=0;
color_write();
delay(10);
if (mode==3){
color_write();
delay(100);
b=255;
g=255;
color_write();
delay(300);
r=0;
color_write();
delay(10);
if (mode==4){
color_write();
delay(100);
b=255;
r=255;
color_write();
delay(300);
r=0;
color_write();
delay(10);
r=r_h;
g=g_h;
b=b_h;
void calibrate()
cal_avg=0;
for (i = 0; i < 50; i++)
cal_avg = (cal_avg+analogRead(micPin));
cal_avg=(cal_avg/50);
potValue=cal_avg;
