Hey
I am extremely new to all of this and came across Arduino only by research. Help and suggestions would be great!
I am wondering whether I can have an arduino board that activates electro pneumatic solenoids (that will let air through a component) and makes sure a certain pressure is reached in a certain time using a pressure transducer (one that relays back in anolouge signal) as the means of detecting it. Then in the same cycle if you like, the same again would need to happen but a solenoid opening a vacuum line that tests the components ability to hold a vacuum. After the cycle it would need to flash up with a pass or fail light for both the vacuum and pressure test.
Thankypu very much
