I have an indoor garden I'm starting and I want to control the system using a few solid state relays and an arduino, I have a couple of temp/humid sensors coming from SFE and a few relays.
The setup I'm looking for is something like this:
Initial Setup will be 1 Grow Light, 1 Water Pump, 1 Fan and 2 Temp/Humid Sensors
The Relays will control the Grow Light, Water Pump and Fan
The 2 Temp/Humid sensors will feed data over serial (XBee)to my Server (which will interpret the data and display on a webpage) which I can access anywhere with my phone or tablet making it easy to checkup on my plants anytime.
I plan on expanding after 1-2 successful harvests to 3 Total Grow Lights, 3 Water pumps and 6-8 total Temp/Humid Sensors, I'm thinking at this point I'll probably split the system into 2-3 components breaking off the relays to their own Arduino and the sensors on another multiplexing them together, does that sound feasible?
Here is where it gets tricky, I'm looking for a way to get the current length of time the relay has been off or on to display in my output giving me an idea of when the state will change
From what I have seen my code should do everything I want/need except as I mentioned the current length of time.
Does anyone know if thats possible with the EventFuse Lib?
Does my setup currently sound feasible?
Does my future setup sound feasible?
Comments/Suggestions PLEASE
Here is the Code I have so far... I'm pulling in a couple of libraries EventFuse(timer) and STH1x(sensor)
* GrowControl Application
* Current design goals
* 2 SHT-15 Temp and Humidity Sensors
* Control 1 Light
* Control 1 Water Pump
//Include Lib for Temp/Humd Sensors
#include <SHT1x.h>
//Include Libs for Event Timers
#include <EventFuse.h>
#include <mstimer2.h>
#define SW_NAME "GrowControl"
#define SW_VERSION ".01 alpha";
//outputs for eventfuse.h
#define OffTime 0
#define OnTime 1
#define OutputPin 2
//Number of Seconds in 24hr 86400 , 12hr 43200 , 6hr 21600
// off / on / pin
byte outputs[OutputCount][2] = {{ 21600, 43200, 7}, //Light 1 Schedule - 18hrs on 6hrs off
{ 3600, 60, 8}, //Water 1 Schedule - 1 min on 60 off (needs to be tweaked)
{ 21600, 43200, 9},}; //Fan 1 Schedule - Current Schedule matches lights (needs to be tweaked and moved to temp control)
//OutputHandler for Relay Controls Via EventFuse Library
void OutputHandler(FuseID fuseID, int outputID){
//which pin to use
byte pin = outputs[outputID][OutputPin];
//get and invert current pin state and write it back
int state = 1&~digitalRead(pin);
digitalWrite( pin,state );
//reset fuse length with new interval
eventFuse[fuseID].fuseLen = outputs[OutputID][state];
void timerTick(){
eventFuse.burn(1);
// Specify data and clock connections and instantiate an SHT1x object
// Canopy Sensor
#define sensor1Data 10
#define sensor1Clock 11
SHT1x sensor1(sensor1Data, sensor1Clock);
// Base Sensor
#define sensor2Data 12
#define sensor2Clock 13
//Specify Light Relay pin
#define light1pin 2;
//Specify Water Relay pin
#define water1pin 4;
Serial.begin(38400); // Open serial connection to report values to host
Serial.println( SW_NAME + SW_VERSION );
Serial.println( "Starting Up Please Wait..." );
//Setup and set all Relay outputs to off
for (byte i = 0; i <OutputCount; i++){
pinMode( outputs[i][OutputPin], OUTPUT );
digitalWrite( outputs[i][OutputPin], LOW);
//Setup EventFuse for Output
eventFuse.newFuse( i, outputs[i][OffTime], INF_REPEAT, OutputHandler );
MsTimer2::set(1000, timerTick);
MsTimer2::start();
Serial.print("Sensor1 Data: ");
getSensorData(sensor1);
Serial.print("Sensor2 Data: ");
getSensorData(sensor2);
//Light Status
Serial.print("Light1: ");
getStatus(light1pin);
//Water Status
Serial.print("Water1: ");
getStatus(water1pin);
delay(2000);
void getStatus(int pin){
//get the status of the pin sent to this funtion
int state = digitalRead(pin);
if (state == 0){
//The pin is low indicating the relay is off
Serial.print(" Off ");
} else if (state == 1){
//The pin is high indicating the relay is on
Serial.print(" On ");
void getSensorData(SHT1x sensor){
float temp_c;
float temp_f;
float humidity;
// Read values from the sensor1
temp_c = sensor.readTemperatureC();
temp_f = sensor.readTemperatureF();
humidity = sensor.readHumidity();
// Print the values to the serial port
Serial.print("Temperature: ");
Serial.print(temp_c, DEC);
Serial.print("C / ");
Serial.print(temp_f, DEC);
Serial.print("F. Humidity: ");
Serial.print(humidity);
Serial.println("%");
