Arduino controlled mosfet driverwont switch.
raschemmel:
...the TC4427 was designed to drive mosfets. It works fine when used that way.
Put 12V on Vdd and drive it with a 5V output from the arduino and you will see 12V on the output.
The TC4427 datasheet specifies the "Supply Voltage Operating Range" as 4.5V to 18V. So, it should work at 5V. And it should drive an LED the way the OP is attempting.
raschemmel:
@ReverseEMF,The only one getting emotional here is you.
Try leaving it out and just discussing the technical details , like the fact that the TC4427 was designed
There is no reason to be so argumentative. No one is being emotional at all.
As has been posted several times 5v is within the operating range of the TC4427 driver. I also had originally posted that I started with a mosfet on the output with 12v on Vdd and it would not turn off the mosfet when switched off. That's why I posted the test circuit above with the LED as a test. If it wont turn off an LED how can I expect it to turn off a mosfet?
I'm thinking that ReverseEMF is the only one here who has actually read the entire thread.
Did you read the datasheet for the mosfet ?
If you read it I think you will find that you need -10V to turn it off.
That's been your problem since the beginning. Only a logic level mosfet will turn off with 0V.
Most require at least -7V to turn off.
If you try connecting -10V to the mosfet gate I think you will find it turns off.
The TC4427 is not a bipolar device so you would need one that runs off a +/- power supply voltage.
The TC4427 has been a waste of time if you are trying to drive a mosfet that requires a negative
voltage to turn off. Try turning off the mosfet with a 9V battery connected with the "+" to GND.'
I don't know why the TC4427 won't turn off the led but I believe that is a different issue than why it
won't turn off the mosfet.
Can you verify how you have the LED connected on the protoboard.
In you picture it looks like you have positioned so both its pins are shorted at pin3 of the 4427.
Shouldn't the resistor and diode connection be on a separate row?
Tom... :slight_smile:
Seems correct.
Pin3 of the chip is ground, and the LED/resistor is connected between output(7) and ground.
Pin4 (second unused input) should be grounded too.
I think it's time to try a new chip.
Like all mosfet parts, handle it with ESD precautions.
Leo..
raschemmel:
I have, and I can find no reference to requiring -10v to turn off. Voltage is relative. Do you mean -10v relative to drain? because that would just be ground.
post the datasheet
Relative to the gate of course.
raschemmel:
post the datasheet
Ok, so when the gate is charged with 12v what is the voltage at the gate? And then when switched to ground what is the voltage relative to the gate?
Have you got your test circuit like this, and running the blink code with 3000 delay?
That is so you can see the changing voltage on the input and output pins with a DMM.
Thanks.. Tom,, :slight_smile:
I looked at an old datasheet, and while it has min/max input values relative to VDD, it only lists a max VDD of 21VDC. All the characteristics are listed using a VDD of 18VDC. Perhaps increase the voltage on VDD to the 12VDC you plan on using anyhow and see if it makes a difference in operation.
Why do you need such a high current mosfet ?
The voltage relative to the gate would be -12V.
I still think you should try connecting the "+" side of a 9V battery to the GND and "-" side to the gate.
You haven't had any luck with anything else . That should turn it off.
I wouldn't waste any more time with the TC4427, unless you are going to try running it off +12V, which
always worked for me.
Adding a pull down resistor to the signal input (TC4427 pin 2) seems to fix the problem. I was erroneously assuming that the atmega328 had internal pull down resistors. It only has a pull up resistor. So digitalWrite(3, LOW); isn't low enough. Seems to be the same as leaving the pin floating.
Pull up/down resistor are not needed if the pin is set to OUTPUT with pinMode.
An Arduino pin has an internal mosfet switch to VCC and a mosfet switch to ground.
Maybe your Arduino pin is damaged (assuming you did set the pin to OUTPUT).
Leo..
Try your code from another PWM pin on the UNO without the pulldown.
Tom.. :slight_smile:
Tried changing the arduino ouput pin and left out the pull down resistor and it works. Set the output back to pin 3 and the LED is stuck on. Put in another atmega328 chip and wrote the same sketch with the output on pin 3 and now its working. So there it is, an atmega chip with a bad pin.
Holy crabcakes -- I step away for a few hours and all heck breaks loose :wink:
You are being pummeled with so much misinformation, I'm not surprised you're confused.
This is absolutely correct. So, it's not clear why adding a pull down resistor would make a difference. The TC4427 datasheet gives a worst case max input low voltage of 0.8V. In other words, as long as the voltage on TC4427's pin 2 is 0.8V, or lower, in relation to TC4427's pin 3, the output should go low. But, there's a thought -- have you measured the voltage on pin 3 (right on pin 3), with the negative probe on the Arduino ground pin [in other words, the positive probe on pin 3 and the negative probe on at the point where Gnd is supplied by the Arduino? If it isn't 0, then we could be on to something, there. Could be some sort of ground loop [doesn't seem likely with the relatively small current caused by the LED -- but who knows?] .
Totally ridiculous! The IRF3205 is an N-Channel MOSFET. And why are we talking about "voltage relative to the gate"?!? The datasheet specs voltages relevant to the gate, as relative to the source. And these are positive voltages. The IRF3205 datasheet specs the RDS(on) [of 8mΩ] at 10V [POSITIVE 10V] -- which, BTW, is a good indication that this is truly not a Logic Level MOSFET BUT, esgeroth has stated that he/she intends to drive it with 12V on the TC4427 VDD pin, so that is quite sufficient to drive this MOSFET.
BUT, to get a fix on WHY this thing isn't working, esgeroth is running it at 5V, which, according to the Datasheet, should work.
BUT, it would be informative for esgeroth to apply 12V to the TC4427 VDD pin, and then change R1 to something more like 420Ω.
Then that datasheet is bogus. The datasheet esgeroth provided shows this MOSFET to be a 55V device, with voltages like 55 and 44 used in the characterizations.
*That's a good idea. At such a low frequency the Arduino output will be more in line with your manuel test, where you physically connected 5V to the input, then 0V to the input. *
328 Output circuit;
Lower MOSFET may have got zapped, though strange it went open circuit.
All an all , there was something to be learned from this post:
1-know when and how to test the ATMega328 digital outputs. (I use a walking bit sketch that cycles all the outputs one a time from H to L and then back to high and repeats on all the outputs. It's a test setup on a breadboard with leds connected to the outputs. I have a 28 pin ZIFF socket
I have a 100k pot with a knurled knob connected across +5V and GND with a wire from the wiper to plug into the analog inputs when I want to test those.
2- When interfacing the TC4427 to an arduino, if the output won't turn off, first try the easiest solution, which is a pulldown resistor on the output of the ATMega328 (the TC4427 input)
3- Configure outputs as outputs if you intend to use them as such.
So, back the IRF3205.
Is it , or is it not turning OFF now ?
As I recall, this was the original issue.
Were you able to turn off the mosfet by just grounding the gate ? (not using the TC4427)
Were you able to turn off the mosfet with the TC4427 after you got the led to turn off by replacing the
ATMega328 chip ?
raschemmel:
Don't you mean, manually apply 5V to the input, then measure the output, then apply Gnd to the input, and again measure the output? Verify that it complies with the following table:
Input TC4426 TC4427 TC4428
IN A ~OUT A OUT A ~OUT A
IN B ~OUT B OUT B OUT B
I don't understand what applying a "pull down" resistor achieves? If the Arduino output is compromised, then item #1 will catch that.
Correct me I am wrong, but didn't the OP start this post with the comment that he did exactly what you just described: (Reply # 15)
When pin2 is connected to ground pin7 reads 0v.
When pin2 is connected to Vdd(5v) pin7 reads 5v.
When pin2 is connected to the arduino output pin then pin7 always reads 5v.
yet here we are on Reply# 58 and the OP didn't find the root cause until Reply# 54:
The point is , the easiest test is add the pull-down resistor, if that fixes the problem then it points to a defective ATMega328, and replacement (or testing) thereof. If your comment:
was that useful, then why did it take 39 posts (54-15) to find the problem ?
